Important question about motor control
JonAnder_Amante
I am using the board S32K344MINI-EVB with driver GD3000 and Sunrise motor. I have tested a program where you can manage the speed of motor with the project "S32K344:mc_pmsm_1sh_s32ct". I have different questions because I want to prove new options.
1. I want to use the evaluation board to realize the control of motor, so I want to do the control FOC (2 controllers PI) but I want to simulate the plant (the motor PMSM) and the power electronics (GD3000). In this example, how I can modify it to simulate the plant but continue perfoming the control from the evaluation board? I suppose that I have to change something of state machine block but I don´t know what I have to change.
2. Could you tell me the pins that I am using to send different signals from GD3000 (driver of motor) to motor PMSM? I have information in your website about this but I don´t if that´s the case. I send you a pdf with this information, although it´s not yhe same board I think the pins are the same (INFO_Driver_MOtor.pdf).
Thank you for all,
Jon Ander Amante
stefanvlad
Hi @JonAnder_Amante ,
In order to use the S32K344MINI-EVB, the following modifications are needed on the board:
1. Remove resistors R396 and R397, located on bottom PCB near DC Jack:
2. Populate with 0 (zero) Ohm  resistors R413, R414 and R418 located near J4 connector:
And also because the VDD_HV_A is supplied with 3.3V instead of 5V:
We need to modify the parameters for the Udc and Idc Gains:
%% Application scales
MBD_I_MAX = 20.625;
MBD_U_DCB_MAX = 29.7;
After this we can connect the DEVKIT-MOTORGD (GD3000) board on top of S32K344MINI-EVB:
Now Open FreeMASTER and run the example and check iABC waveforms:
Stefan V.
JonAnder_Amante
Thank you for your reply. At now, I want to realize only the control of FOC in the board "S32K344 MINI-EVB", that is to say, I have another block of the plant that it´s represented the motor PMSM (Sunrise) with power electronics but I have to use the control of FOC with MBD. In this example, could you tell me which block I have to keep and what blocks I have to remove?
I think that I have to keep the current loop and speed loop in the block called "state machine" but the problem is there are many variables and different blocks with different jumps between them.
Basically, my project´s target is to use the same control of FOC from this project but to use another plant.
Thank you for all,
Jon Ander Amante
stefanvlad
I am not sure i understand what other plant you want to use, another motor maybe?
We currently support the Sunrise Motor with parameters in s32k344_mc_pmsm_2sh_s32ct_data.m and Linix Motor with parameters in s32k344_mc_pmsm_2sh_s32ct_data_linix.m
If you have any other motors, you will need to modify the parameters accordingly in data.m files, then do a clean Build.
Have a good day,
Stefan V.
JonAnder_Amante
1. I want to use Sunrise motor with its parameters but my question is if there is any block in SImulink that represents the plant because I want to have a block of the plant on one hand and the controller on the other.
2. Moreover, I send you the parameters of motor Sunrise and I don´t know if you can confirm that the dates are true.
PARAM_Rs = 0.192; % Resistencia del estator [Ohms]
PARAM_Mpp = 2; % Pares de polos [-]
PARAM_Ld = 0.000096; % Inductancia eje D [H]
PARAM_Lq = 0.000107; % Inductancia eje Q [H]
PARAM_Ke = 0.005872; % Constante Back-EMF [V.sec/rad]
PARAM_J = 0.12e-4; % Inercia [kg.m2]
PARAM_r32_F_IP_Wb_motor1 = 0.00518; % Flujo magnetico
%% Parametros diseño LAZO DE CORRIENTE
%Loop Bandwidth = 150 [Hz]
%Loop Attenuation = 1 [-]
%Loop sample time = 0.0001 [sec]
f_cutoff_current = 150; % Frecuencia de corte deseada [Hz]
w0_current = 2 * pi * f_cutoff_current; % Frecuencia natural [rad/s]
xi_current = 0.707; % Amortiguamiento
Ts_current = 1 /fsw; % Tiempo de muestreo
% Cálculos eje D
Kp_D = (2 * xi_current * w0_current * PARAM_Ld) - PARAM_Rs;
Ki_D = (w0_current^2) * PARAM_Ld;
% Cálculos eje Q
Kp_Q = (2 * xi_current * w0_current * PARAM_Lq) - PARAM_Rs;
Ki_Q = (w0_current^2) * PARAM_Lq;
% Current Loop Control (Calculado según NXP GFLIB)
MBD_CLOOP_LIMIT = 0.9;
% Eje D (D-axis)
MBD_D_CC1SC = Kp_D + (Ki_D * Ts_current / 2);
MBD_D_CC2SC = -Kp_D + (Ki_D * Ts_current / 2);
% Eje Q (Q-axis)
MBD_Q_CC1SC = Kp_Q + (Ki_Q * Ts_current / 2);
MBD_Q_CC2SC = -Kp_Q + (Ki_Q * Ts_current / 2);
2. I send you the scheme that I am using in Simulink. My idea is
My idea is to not use the physical motor and to simulate it with the green block you see in the photos. and to perform the control (current loop and speed loop) with the MCLIB blocks.
Thank you for all;
dragostoma
Hi, @JonAnder_Amante,
You can find the answer to the initial thread here: missing Motor Control PMSM example in the 1.60 version of the S32K3 MBDT
Dragos
JonAnder_Amante
Good morning,
I am using one of your evaluation boards, specifically the FRDM-A-S32K344 board, with the ‘S32K344_mc_pmsm_1sh_s32ct’ example in MATLAB and Simulink. The problem I’m having is that when I connect the interface to the Freemaster, some variables don’t appear and show up as a question mark; in other words, they aren’t being detected or aren’t implemented. Also, I’m trying to load the .elf file in case there was a compilation error, and I’m getting some errors saying that certain variables aren’t being detected.
Could you help me?
If i try to reload the file .elf I have:
SorinIBancila
If variables are not detected in the FreeMASTER project make sure that the elf file is properly selected from the settings.
If it is properly set, check in the model if the variables are set to External or Volatile. Otherwise, the FreeMASTER is not able to detect them.
Sorin Bancila
%3CLINGO-SUB%20id%3D%22lingo-sub-2305902%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EImportant%20question%20about%20motor%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2305902%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20am%20using%20the%20board%20%3CSPAN%3ES32K344MINI-EVB%20with%20driver%20GD3000%20and%20Sunrise%20motor.%20I%20have%20tested%20a%20program%20where%20you%20can%20manage%20the%20speed%20of%20motor%20with%20the%20project%20%22S32K344%3Amc_pmsm_1sh_s32ct%22.%20I%20have%20different%20questions%20because%20I%20want%20to%20prove%20new%20options.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JonAnder_Amante_1-1770196663700.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770196663700.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770196663700.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770196663700.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770196663700.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770196663700.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770196663700.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770196663700.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770196663700.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F375465i21E8D42A1779FE60%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JonAnder_Amante_1-1770196663700.png%22%20alt%3D%22JonAnder_Amante_1-1770196663700.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E1.%20I%20want%20to%20use%20the%20evaluation%20board%20to%20realize%20the%20control%20of%20motor%2C%20so%20I%20want%20to%20do%20the%20control%20FOC%20(2%20controllers%20PI)%20but%20I%20want%20to%20simulate%20the%20plant%20(the%20motor%20PMSM)%20and%20the%20power%20electronics%20(GD3000).%20In%20this%20example%2C%20how%20I%20can%20modify%20it%20to%20simulate%20the%20plant%20but%20continue%20perfoming%20the%20control%20from%20the%20evaluation%20board%3F%3C%2FSPAN%3E%26nbsp%3BI%20suppose%20that%20I%20have%20to%20change%20something%20of%20state%20machine%20block%20but%20I%20don%C2%B4t%20know%20what%20I%20have%20to%20change.%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3E2.%20Could%20you%20tell%20me%20the%20pins%20that%20I%20am%20using%20to%20send%20different%20signals%20from%20GD3000%20(driver%20of%20motor)%20to%20motor%20PMSM%3F%20I%20have%20information%20in%20your%20website%20about%20this%20but%20I%20don%C2%B4t%20if%20that%C2%B4s%20the%20case.%20I%20send%20you%20a%20pdf%20with%20this%20information%2C%20although%20it%C2%B4s%20not%20yhe%20same%20board%20I%20think%20the%20pins%20are%20the%20same%20(INFO_Driver_MOtor.pdf).%3C%2FP%3E%3CP%3EThank%20you%20for%20all%2C%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EJon%20Ander%20Amante%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2313837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Important%20question%20about%20motor%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2313837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226147%22%20target%3D%22_blank%22%3E%40JonAnder_Amante%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EYou%20can%20find%20the%20answer%20to%20the%20initial%20thread%20here%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2Fmissing-Motor-Control-PMSM-example-in-the-1-60-version-of-the%2Fm-p%2F2313448%2Fhighlight%2Ftrue%23M10626%22%20target%3D%22_blank%22%3Emissing%20Motor%20Control%20PMSM%20example%20in%20the%201.60%20version%20of%20the%20S32K3%20MBDT%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EDragos%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2316523%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Important%20question%20about%20motor%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2316523%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226147%22%20target%3D%22_blank%22%3E%40JonAnder_Amante%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EIn%20order%20to%20use%20the%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FS32K344MINI-EVB%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32K344MINI-EVB%3C%2FA%3E%2C%26nbsp%3Bthe%20following%20modifications%20are%20needed%20on%20the%20board%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_0-1770819182442.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1770819182442.png%22%20style%3D%22width%3A%20850px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1770819182442.png%22%20style%3D%22width%3A%20850px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1770819182442.png%22%20style%3D%22width%3A%20850px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1770819182442.png%22%20style%3D%22width%3A%20850px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1770819182442.png%22%20style%3D%22width%3A%20850px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1770819182442.png%22%20style%3D%22width%3A%20850px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376521iE9EA517CF495AD10%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_0-1770819182442.png%22%20alt%3D%22stefanvlad_0-1770819182442.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E1.%20Remove%20resistors%20%3CSTRONG%3ER396%3C%2FSTRONG%3E%20and%20%3CSTRONG%3ER397%3C%2FSTRONG%3E%2C%20located%20on%20bottom%20PCB%20near%20DC%20Jack%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_4-1770819788524.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_4-1770819788524.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_4-1770819788524.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_4-1770819788524.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_4-1770819788524.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_4-1770819788524.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_4-1770819788524.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376529i8EB250BFC515F804%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_4-1770819788524.png%22%20alt%3D%22stefanvlad_4-1770819788524.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E2.%20Populate%20with%200%20(%3CSTRONG%3Ezero%3C%2FSTRONG%3E)%20Ohm%26nbsp%3B%20resistors%20%3CSTRONG%3ER413%3C%2FSTRONG%3E%2C%20%3CSTRONG%3ER414%3C%2FSTRONG%3E%20and%20%3CSTRONG%3ER418%20%3C%2FSTRONG%3Elocated%20near%20J4%20connector%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_3-1770819728806.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_3-1770819728806.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_3-1770819728806.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_3-1770819728806.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_3-1770819728806.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_3-1770819728806.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_3-1770819728806.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376527iA7C8E7C849E35ABB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_3-1770819728806.png%22%20alt%3D%22stefanvlad_3-1770819728806.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EAnd%20also%20because%20the%20VDD_HV_A%20is%20supplied%20with%203.3V%20instead%20of%205V%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_2-1770819465940.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1770819465940.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1770819465940.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1770819465940.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1770819465940.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1770819465940.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1770819465940.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376524i09EFFBC617C5A3C4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_2-1770819465940.png%22%20alt%3D%22stefanvlad_2-1770819465940.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EWe%20need%20to%20modify%20the%20parameters%20for%20the%20Udc%20and%20Idc%20Gains%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_6-1770820165900.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_6-1770820165900.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_6-1770820165900.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_6-1770820165900.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_6-1770820165900.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_6-1770820165900.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_6-1770820165900.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376533iD0B6B26893B98002%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_6-1770820165900.png%22%20alt%3D%22stefanvlad_6-1770820165900.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CDIV%20class%3D%22rtcContent%22%3E%0A%3CDIV%20class%3D%22lineNode%22%3E%3CSPAN%3E%25%25%20Application%20scales%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lineNode%22%3E%3CSPAN%3EMBD_I_MAX%20%3D%2020.625%3B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lineNode%22%3E%3CSPAN%3EMBD_U_DCB_MAX%20%3D%2029.7%3B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lineNode%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lineNode%22%3E%3CSPAN%3EAfter%20this%20we%20can%20connect%20the%20DEVKIT-MOTORGD%20(GD3000)%20board%20on%20top%20of%20S32K344MINI-EVB%3A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lineNode%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_5-1770819975008.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_5-1770819975008.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_5-1770819975008.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_5-1770819975008.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_5-1770819975008.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_5-1770819975008.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_5-1770819975008.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376530iD9521C936A58AEE3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_5-1770819975008.jpeg%22%20alt%3D%22stefanvlad_5-1770819975008.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3ENow%20Open%20FreeMASTER%20and%20run%20the%20example%20and%20check%20iABC%20waveforms%3A%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_7-1770821519787.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_7-1770821519787.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_7-1770821519787.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_7-1770821519787.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_7-1770821519787.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_7-1770821519787.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_7-1770821519787.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376534iB675226DFEEF715E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_7-1770821519787.png%22%20alt%3D%22stefanvlad_7-1770821519787.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%26nbsp%3BBest%20regards%2C%3C%2FP%3E%0A%3CP%3EStefan%20V.%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2316910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Important%20question%20about%20motor%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2316910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EThank%20you%20for%20your%20reply.%20At%20now%2C%20I%20want%20to%20realize%20only%20the%20control%20of%20FOC%20in%20the%20board%20%22S32K344%20MINI-EVB%22%2C%20that%20is%20to%20say%2C%20I%20have%20another%20block%20of%20the%20plant%20that%20it%C2%B4s%20represented%20the%20motor%20PMSM%20(Sunrise)%20with%20power%20electronics%20but%20I%20have%20to%20use%20the%20control%20of%20FOC%20with%20MBD.%20In%20this%20example%2C%20could%20you%20tell%20me%20which%20block%20I%20have%20to%20keep%20and%20what%20blocks%20I%20have%20to%20remove%3F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JonAnder_Amante_0-1770883302148.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_0-1770883302148.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_0-1770883302148.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_0-1770883302148.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_0-1770883302148.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_0-1770883302148.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376633iCDB15E67391B9421%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JonAnder_Amante_0-1770883302148.png%22%20alt%3D%22JonAnder_Amante_0-1770883302148.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EI%20think%20that%20I%20have%20to%20keep%20the%20current%20loop%20and%20speed%20loop%20in%20the%20block%20called%20%22state%20machine%22%20but%20the%20problem%20is%20there%20are%20many%20variables%20and%20different%20blocks%20with%20different%20jumps%20between%20them.%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JonAnder_Amante_1-1770883826681.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770883826681.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770883826681.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770883826681.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770883826681.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1770883826681.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376636i5060B73E4FB4463C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JonAnder_Amante_1-1770883826681.png%22%20alt%3D%22JonAnder_Amante_1-1770883826681.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBasically%2C%20my%20project%C2%B4s%20target%20is%20to%20use%20the%20same%20control%20of%20FOC%20from%20this%20project%20but%20to%20use%20another%20plant.%3CBR%20%2F%3E%3CBR%20%2F%3EThank%20you%20for%20all%2C%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EJon%20Ander%20Amante%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2317212%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Important%20question%20about%20motor%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2317212%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226147%22%20target%3D%22_blank%22%3E%40JonAnder_Amante%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20am%20not%20sure%20i%20understand%20what%20other%20plant%20you%20want%20to%20use%2C%20another%20motor%20maybe%3F%3C%2FP%3E%0A%3CP%3EWe%20currently%20support%20the%20%3CSTRONG%3ESunrise%20Motor%3C%2FSTRONG%3E%20with%20parameters%20in%20%3CSTRONG%3Es32k344_mc_pmsm_2sh_s32ct_data%3C%2FSTRONG%3E.%3CSTRONG%3Em%3C%2FSTRONG%3E%20and%20Linix%20Motor%20with%20parameters%20in%20s32k344_mc_pmsm_2sh_s32ct_data_linix.m%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EIf%20you%20have%20any%20other%20motors%2C%20you%20will%20need%20to%20modify%20the%20parameters%20accordingly%20in%20data.m%20files%2C%20then%20do%20a%20clean%20Build.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20a%20good%20day%2C%3C%2FP%3E%0A%3CP%3EStefan%20V.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2318452%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Important%20question%20about%20motor%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2318452%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CBR%20%2F%3E%3CBR%20%2F%3E1.%20I%20want%20to%20use%20Sunrise%20motor%20with%20its%20parameters%20but%20my%20question%20is%20if%20there%20is%20any%20block%20in%20SImulink%20that%20represents%20the%20plant%20because%20I%20want%20to%20have%20a%20block%20of%20the%20plant%20on%20one%20hand%20and%20the%20controller%20on%20the%20other.%26nbsp%3B%3C%2FP%3E%3CP%3E2.%20Moreover%2C%20I%20send%20you%20the%20parameters%20of%20motor%20Sunrise%20and%20I%20don%C2%B4t%20know%20if%20you%20can%20confirm%20that%20the%20dates%20are%20true.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EPARAM_Rs%20%3D%200.192%3B%20%25%20Resistencia%20del%20estator%20%5BOhms%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EPARAM_Mpp%20%3D%202%3B%20%25%20Pares%20de%20polos%20%5B-%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EPARAM_Ld%20%3D%200.000096%3B%20%25%20Inductancia%20eje%20D%20%5BH%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EPARAM_Lq%20%3D%200.000107%3B%20%25%20Inductancia%20eje%20Q%20%5BH%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EPARAM_Ke%20%3D%200.005872%3B%20%25%20Constante%20Back-EMF%20%5BV.sec%2Frad%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EPARAM_J%20%3D%200.12e-4%3B%20%25%20Inercia%20%5Bkg.m2%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EPARAM_r32_F_IP_Wb_motor1%20%3D%200.00518%3B%20%25%20Flujo%20magnetico%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25%25%20Parametros%20dise%C3%B1o%20LAZO%20DE%20CORRIENTE%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25Loop%20Bandwidth%20%3D%20150%20%5BHz%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25Loop%20Attenuation%20%3D%201%20%5B-%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25Loop%20sample%20time%20%3D%200.0001%20%5Bsec%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25-----------------------------------------------------%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3Ef_cutoff_current%20%3D%20150%3B%20%25%20Frecuencia%20de%20corte%20deseada%20%5BHz%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3Ew0_current%20%3D%202%20*%20pi%20*%20f_cutoff_current%3B%20%25%20Frecuencia%20natural%20%5Brad%2Fs%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3Exi_current%20%3D%200.707%3B%20%25%20Amortiguamiento%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3ETs_current%20%3D%201%20%2Ffsw%3B%20%25%20Tiempo%20de%20muestreo%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25%20C%C3%A1lculos%20eje%20D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EKp_D%20%3D%20(2%20*%20xi_current%20*%20w0_current%20*%20PARAM_Ld)%20-%20PARAM_Rs%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EKi_D%20%3D%20(w0_current%5E2)%20*%20PARAM_Ld%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25%20C%C3%A1lculos%20eje%20Q%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EKp_Q%20%3D%20(2%20*%20xi_current%20*%20w0_current%20*%20PARAM_Lq)%20-%20PARAM_Rs%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EKi_Q%20%3D%20(w0_current%5E2)%20*%20PARAM_Lq%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25%20Current%20Loop%20Control%20(Calculado%20seg%C3%BAn%20NXP%20GFLIB)%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25----------------------------------------------------------------------%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EMBD_CLOOP_LIMIT%20%3D%200.9%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25%20Eje%20D%20(D-axis)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EMBD_D_CC1SC%20%3D%20Kp_D%20%2B%20(Ki_D%20*%20Ts_current%20%2F%202)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EMBD_D_CC2SC%20%3D%20-Kp_D%20%2B%20(Ki_D%20*%20Ts_current%20%2F%202)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%25%20Eje%20Q%20(Q-axis)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EMBD_Q_CC1SC%20%3D%20Kp_Q%20%2B%20(Ki_Q%20*%20Ts_current%20%2F%202)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3EMBD_Q_CC2SC%20%3D%20-Kp_Q%20%2B%20(Ki_Q%20*%20Ts_current%20%2F%202)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CP%3E2.%20I%20send%20you%20the%20scheme%20that%20I%20am%20using%20in%20Simulink.%20My%20idea%20is%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JonAnder_Amante_1-1771229540348.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1771229540348.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1771229540348.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1771229540348.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376908i66C9513943847B05%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JonAnder_Amante_1-1771229540348.png%22%20alt%3D%22JonAnder_Amante_1-1771229540348.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JonAnder_Amante_2-1771229553893.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_2-1771229553893.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_2-1771229553893.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_2-1771229553893.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376909i5A97B7E58B87D855%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JonAnder_Amante_2-1771229553893.png%22%20alt%3D%22JonAnder_Amante_2-1771229553893.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JonAnder_Amante_4-1771229596623.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_4-1771229596623.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_4-1771229596623.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_4-1771229596623.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376911iF3EEAB279A38539B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JonAnder_Amante_4-1771229596623.png%22%20alt%3D%22JonAnder_Amante_4-1771229596623.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JonAnder_Amante_3-1771229577117.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_3-1771229577117.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_3-1771229577117.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_3-1771229577117.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376910iA5F1CE9D7CE36E11%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JonAnder_Amante_3-1771229577117.png%22%20alt%3D%22JonAnder_Amante_3-1771229577117.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EMy%20idea%20is%20to%20not%20use%20the%20physical%20motor%20and%20to%20simulate%20it%20with%20the%20green%20block%20you%20see%20in%20the%20photos.%20and%20to%20perform%20the%20control%20(current%20loop%20and%20speed%20loop)%20with%20the%20MCLIB%20blocks.%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CP%3EThank%20you%20for%20all%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2375632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Important%20question%20about%20motor%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2375632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGood%20morning%2C%3C%2FP%3E%3CP%3EI%20am%20using%20one%20of%20your%20evaluation%20boards%2C%20specifically%20the%20FRDM-A-S32K344%20board%2C%20with%20the%20%E2%80%98S32K344_mc_pmsm_1sh_s32ct%E2%80%99%20example%20in%20MATLAB%20and%20Simulink.%20The%20problem%20I%E2%80%99m%20having%20is%20that%20when%20I%20connect%20the%20interface%20to%20the%20Freemaster%2C%20some%20variables%20don%E2%80%99t%20appear%20and%20show%20up%20as%20a%20question%20mark%3B%20in%20other%20words%2C%20they%20aren%E2%80%99t%20being%20detected%20or%20aren%E2%80%99t%20implemented.%20Also%2C%20I%E2%80%99m%20trying%20to%20load%20the%20.elf%20file%20in%20case%20there%20was%20a%20compilation%20error%2C%20and%20I%E2%80%99m%20getting%20some%20errors%20saying%20that%20certain%20variables%20aren%E2%80%99t%20being%20detected.%3C%2FP%3E%3CP%3ECould%20you%20help%20me%3F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JonAnder_Amante_0-1780475763418.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_0-1780475763418.png%22%20style%3D%22width%3A%20364px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_0-1780475763418.png%22%20style%3D%22width%3A%20364px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F387668i30BD9F7808C88CED%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JonAnder_Amante_0-1780475763418.png%22%20alt%3D%22JonAnder_Amante_0-1780475763418.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JonAnder_Amante_1-1780475763497.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1780475763497.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_1-1780475763497.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F387666i4722121C0F6DC2EB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JonAnder_Amante_1-1780475763497.png%22%20alt%3D%22JonAnder_Amante_1-1780475763497.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CBR%20%2F%3EIf%20i%20try%20to%20reload%20the%20file%20.elf%20I%20have%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JonAnder_Amante_2-1780475763491.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_2-1780475763491.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JonAnder_Amante_2-1780475763491.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F387667i265344D14F8080CC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JonAnder_Amante_2-1780475763491.png%22%20alt%3D%22JonAnder_Amante_2-1780475763491.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Important%20question%20about%20motor%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20data-olk-copy-source%3D%22MessageBody%22%3EHello%2C%3CBR%20%2F%3E%3CBR%20%2F%3EIf%20variables%20are%20not%20detected%20in%20the%20FreeMASTER%20project%20make%20sure%20that%20the%20elf%20file%20is%20properly%20selected%20from%20the%20settings.%20%3CBR%20%2F%3E%3CBR%20%2F%3EIf%20it%20is%20properly%20set%2C%20check%20in%20the%20model%20if%20the%20variables%20are%20set%20to%20External%20or%20Volatile.%20Otherwise%2C%20the%20FreeMASTER%20is%20not%20able%20to%20detect%20them.%20%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20regards%2C%20%3CBR%20%2F%3ESorin%20Bancila%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
