FS65xx with MPC5744p integration problem
2,121件の閲覧回数
Mashiyojin
Hi Guys,
I want to integrate this MC33FS6523CAE with MPC5744P for basic test function.
But I have been failing many times, only debug mode can success to send can-bus out.
Have anyone done this project before?
could you help share some example for just basic start-up C header ?
Thank you in advanced,
Mashi.
2 返答(返信)
2,104件の閲覧回数
mariuslucianand
Hello @Mashiyojin ,
Unfortunately, we do not have dedicated blocks for that. You can still use the SPI blocks for configuration, most likely using custom code.
You can start with the FS6500/FS4500 Generic SW Driver with Examples from here.
Hope this helps,
Marius
2,084件の閲覧回数
Mashiyojin
Thank you Marius,  I will try it.
By the way, I am working on MPC5744p with MC33771C (TPL).
I saw you have shared this kind of Integration for Simulink (SPI) in below link.
Do you also have some example for TPL case as well ?
https://community.nxp.com/t5/Model-Based-Design-Toolbox-MBDT/MPC5744P-and-MC33771-Configuration/m-p/...
Looking forward to your reply.
Mashi.
タグ(1)
