FCAN problem on RDVCU5775EVM trial board
peaces
I can run the TX command with the FCAN block on the RDVCU5775EVM test card, but when I want to do RX, I can't get any results, the draft of the work I have done is attached.
Is there anyone who can help with this?
PetrS
Hi Marius, @mariuslucianand
are you able to comment this?
Petr
peaces
Has anyone found a solution to the problem?
