EEPROM Read Write
EEPROM Read Write
Partha_G
I am trying to write data directly to the EEPROM of S32K144 using the Flash EEERead/Write blocks  in Simulink.  I am writing the data 61H (97 in decimal) in a separate program and reading the same in another one using the FLASH blocks via CAN bus as mentioned, but I am getting the data as FF instead of 61 on the Busmaster. Please help me out.
Partha_G
Okay! I will check, thank you!
Narudol-T
https://community.nxp.com/t5/Model-Based-Design-Toolbox-MBDT/Flash-EEE-Read-and-Write/m-p/1170584
you can follow this post, it solved my problem.
Thank you,
Narudol T.
