Controlling two FreeMaster instances from one MATLAB script
16,437 次查看
Ahmed_Abd_El-Hafez
Hello NXP team,
I want to make a MATLAB script file that can access, monitor and control two FreeMaster instances. I read the section talking about this in the user guide but still have problems and the example attached was for one FreeMaster and didn't work with me for the two FreeMaster instances. The .m file that I am trying to build , is till now only opens the two files but can't write or read from them. It gives this error:
Dot indexing is not supported for variables of this type.
Error in SingleScriptControlling2FM (line 15)
bSucc = pcm1.ReadVariable('SpeedActRpm');
Does any one have a script for this purpose or can help with this error?
Thank you in advance.
Ahmed
15,113 次查看
MichalH
NXP Apps Support
NXP Apps Support
Hello Ahmed,
I confirm your script (the mmult_test() function) works as expected on my side. I tried on two Windows 11 systems. On a corporate PC with strict security rules, the Excel will not let the script to launch the FreeMASTER processes, so I had to run them manually first:
pcmaster /sharex TRQ
pcmaster /sharex SPD
Then the script was able to get access to running instances. Followed by a message:
...which is obvious as I have an empty project in the TRQ instance.
In the 2nd experiment using my home PC, the Excel was able to launch and control the instances. I'm really not sure what can be blocking the access on your side. Can you try the same on a different PC?
Michal
24 回复数
2,774 次查看
Ahmed_Abd_El-Hafez
Thank you Michal. I attached the excel file.
I tried opening the two instances manually and then run the VBA code to locate them but it also couldn't.
2,765 次查看
Ahmed_Abd_El-Hafez
Hello Michal,
Have you checked the script? the problem still exists.
Ahmed
15,114 次查看
MichalH
NXP Apps Support
NXP Apps Support
Hello Ahmed,
Michal
2,714 次查看
Ahmed_Abd_El-Hafez
I tried it on another PC and it works.
Thank you very much ,Michal.
%3CLINGO-SUB%20id%3D%22lingo-sub-1856051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%80%9A%E8%BF%87%E4%B8%80%E4%B8%AA%20MATLAB%20%E8%84%9A%E6%9C%AC%E6%8E%A7%E5%88%B6%E4%B8%A4%E4%B8%AA%20FreeMaster%20%E5%AE%9E%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1856051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8CNXP%E5%9B%A2%E9%98%9F%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E5%88%B6%E4%BD%9C%E4%B8%80%E4%B8%AA%E5%8F%AF%E4%BB%A5%E8%AE%BF%E9%97%AE%E3%80%81%3CU%3E%3CSTRONG%3E%E7%9B%91%E8%A7%86%E5%92%8C%E6%8E%A7%E5%88%B6%3C%2FSTRONG%3E%3C%2FU%3E%E4%B8%A4%E4%B8%AA%20FreeMaster%20%E5%AE%9E%E4%BE%8B%E7%9A%84%20MATLAB%20%E8%84%9A%E6%9C%AC%E6%96%87%E4%BB%B6%E3%80%82%E6%88%91%E9%98%85%E8%AF%BB%E4%BA%86%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%E4%B8%AD%E8%AE%A8%E8%AE%BA%E6%AD%A4%E9%97%AE%E9%A2%98%E7%9A%84%E9%83%A8%E5%88%86%EF%BC%8C%E4%BD%86%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%89%80%E9%99%84%E7%9A%84%E7%A4%BA%E4%BE%8B%E9%80%82%E7%94%A8%E4%BA%8E%E4%B8%80%E4%B8%AA%20FreeMaster%EF%BC%8C%E5%B9%B6%E4%B8%94%E4%B8%8D%E9%80%82%E7%94%A8%E4%BA%8E%E6%88%91%E7%9A%84%E4%B8%A4%E4%B8%AA%20FreeMaster%20%E5%AE%9E%E4%BE%8B%E3%80%82%E6%88%91%E5%B0%9D%E8%AF%95%E6%9E%84%E5%BB%BA%E7%9A%84%20.m%20%E6%96%87%E4%BB%B6%E5%88%B0%E7%9B%AE%E5%89%8D%E4%B8%BA%E6%AD%A2%E5%8F%AA%E8%83%BD%E6%89%93%E5%BC%80%E4%B8%A4%E4%B8%AA%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E5%86%99%E5%85%A5%E6%88%96%E8%AF%BB%E5%8F%96%E5%AE%83%E4%BB%AC%E3%80%82%E5%AE%83%E7%BB%99%E5%87%BA%E4%BA%86%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E6%AD%A4%E7%B1%BB%E5%9E%8B%E7%9A%84%E5%8F%98%E9%87%8F%E4%B8%8D%E6%94%AF%E6%8C%81%E7%82%B9%E7%B4%A2%E5%BC%95%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF0000%22%3ESingleScriptControlling2FM%20%E4%B8%AD%E5%AD%98%E5%9C%A8%E9%94%99%E8%AF%AF%EF%BC%88%E7%AC%AC%2015%20%E8%A1%8C%EF%BC%89%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF0000%22%3EbSucc%20%3D%20pcm1.%E8%AF%BB%E5%8F%96%E5%8F%98%E9%87%8F('%E9%80%9F%E5%BA%A6%E5%8A%A8%E4%BD%9C%E8%BD%AC%E9%80%9F')%3B%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23000000%22%3E%E6%98%AF%E5%90%A6%E6%9C%89%E4%BA%BA%E6%9C%89%E7%94%A8%E4%BA%8E%E6%AD%A4%E7%9B%AE%E7%9A%84%E7%9A%84%E8%84%9A%E6%9C%AC%E6%88%96%E5%8F%AF%E4%BB%A5%E5%B8%AE%E5%8A%A9%E8%A7%A3%E5%86%B3%E6%AD%A4%E9%94%99%E8%AF%AF%EF%BC%9F%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23000000%22%3E%E6%8F%90%E5%89%8D%E8%B0%A2%E8%B0%A2%E6%82%A8%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23000000%22%3E%E8%89%BE%E5%93%88%E8%BF%88%E5%BE%B7%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1895777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%80%E4%B8%AA%20MATLAB%20%E8%84%9A%E6%9C%AC%E6%8E%A7%E5%88%B6%E4%B8%A4%E4%B8%AA%20FreeMaster%20%E5%AE%9E%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1895777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%9C%A8%E5%8F%A6%E4%B8%80%E5%8F%B0%E7%94%B5%E8%84%91%E4%B8%8A%E5%B0%9D%E8%AF%95%E8%BF%87%EF%BC%8C%E5%AE%83%E5%8F%AF%E4%BB%A5%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%8CMichal%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1886015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%80%E4%B8%AA%20MATLAB%20%E8%84%9A%E6%9C%AC%E6%8E%A7%E5%88%B6%E4%B8%A4%E4%B8%AA%20FreeMaster%20%E5%AE%9E%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1886015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CMichal%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%82%A8%E6%A3%80%E6%9F%A5%E8%BF%87%E8%84%9A%E6%9C%AC%E4%BA%86%E5%90%97%EF%BC%9F%E9%97%AE%E9%A2%98%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%E3%80%82%3C%2FP%3E%3CP%3E%E8%89%BE%E5%93%88%E8%BF%88%E5%BE%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1871048%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%80%E4%B8%AA%20MATLAB%20%E8%84%9A%E6%9C%AC%E6%8E%A7%E5%88%B6%E4%B8%A4%E4%B8%AA%20FreeMaster%20%E5%AE%9E%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1871048%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%8CMichal%E3%80%82%E6%88%91%E9%99%84%E5%8A%A0%E4%BA%86%20Excel%20%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E6%89%8B%E5%8A%A8%E6%89%93%E5%BC%80%E8%BF%99%E4%B8%A4%E4%B8%AA%E5%AE%9E%E4%BE%8B%EF%BC%8C%E7%84%B6%E5%90%8E%E8%BF%90%E8%A1%8C%20VBA%20%E4%BB%A3%E7%A0%81%E6%9D%A5%E6%89%BE%E5%88%B0%E5%AE%83%E4%BB%AC%EF%BC%8C%E4%BD%86%E4%B9%9F%E5%A4%B1%E8%B4%A5%E4%BA%86%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1868984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%80%E4%B8%AA%20MATLAB%20%E8%84%9A%E6%9C%AC%E6%8E%A7%E5%88%B6%E4%B8%A4%E4%B8%AA%20FreeMaster%20%E5%AE%9E%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1868984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%AF%EF%BC%8C%E8%BF%99%E4%BC%BC%E4%B9%8E%20Excel%20VBA%20%E4%B8%AD%E7%9A%84%E2%80%9Cmult%E2%80%9D%E5%AF%B9%E8%B1%A1%E5%9C%A8%E4%BD%BF%E7%94%A8%E6%AD%A3%E7%A1%AE%E7%9A%84%E5%AE%9E%E4%BE%8B%E5%90%8D%E7%A7%B0%E4%BD%9C%E4%B8%BA%E5%8F%82%E6%95%B0%E5%90%AF%E5%8A%A8%20FreeMASTER%20%E6%97%B6%E5%87%BA%E7%8E%B0%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E8%AE%A4%E4%B8%BA%E6%82%A8%E5%9C%A8%E8%B0%83%E7%94%A8%E2%80%9CGetAppObject%E2%80%9D%E6%97%B6%E4%BC%A0%E9%80%92%E5%AE%9E%E4%BE%8B%E5%90%8D%E7%A7%B0%EF%BC%88%E2%80%9CA%E2%80%9D%E6%88%96%E2%80%9CB%E2%80%9D%EF%BC%89%E7%9A%84%E6%96%B9%E5%BC%8F%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%86%20Excel%20%E6%96%87%E4%BB%B6%E4%BD%9C%E4%B8%BA%E9%99%84%E4%BB%B6%E4%B8%8A%E4%BC%A0%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%88%91%E6%9F%A5%E7%9C%8B%E8%84%9A%E6%9C%AC%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%97%A0%E8%AE%BA%E5%A6%82%E4%BD%95%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%8E%E5%91%BD%E4%BB%A4%E8%A1%8C%E6%89%8B%E5%8A%A8%E8%BF%90%E8%A1%8C%E5%90%8D%E4%B8%BA%E2%80%9CA%E2%80%9D%EF%BC%88pcmaster.exe%20%2Fsharex%20A%EF%BC%89%E6%88%96%E5%90%8D%E4%B8%BA%E2%80%9CB%E2%80%9D%EF%BC%88pcmaster.exe%20%2Fsharex%20B%EF%BC%89%E7%9A%84%E5%AE%9E%E4%BE%8B%E3%80%82%E7%84%B6%E5%90%8E%20Excel%20VBA%20%E5%BA%94%E8%AF%A5%E8%83%BD%E5%A4%9F%E6%89%BE%E5%88%B0%E5%AE%83%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3E%E7%B1%B3%E5%93%88%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1868611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%80%E4%B8%AA%20MATLAB%20%E8%84%9A%E6%9C%AC%E6%8E%A7%E5%88%B6%E4%B8%A4%E4%B8%AA%20FreeMaster%20%E5%AE%9E%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1868611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E8%89%BE%E5%93%88%E8%BF%88%E5%BE%B7%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E5%BE%88%E9%AB%98%E5%85%B4%E6%82%A8%E8%83%BD%E9%80%9A%E8%BF%87%20Matlab%20%E5%AE%8C%E6%88%90%E8%BF%99%E9%A1%B9%E5%B7%A5%E4%BD%9C%E3%80%82%E7%8E%B0%E5%9C%A8%E8%AE%A9%E6%88%91%E4%BB%AC%E9%9B%86%E4%B8%AD%E8%AE%A8%E8%AE%BA%20Excel%20%E9%97%AE%E9%A2%98%E3%80%82%E5%BD%93%E5%AE%83%E5%90%AF%E5%8A%A8%E4%B8%A4%E4%B8%AA%E6%96%B0%E5%AE%9E%E4%BE%8B%E6%97%B6%20-%20VBA%20%E8%84%9A%E6%9C%AC%E6%98%AF%E5%90%A6%E4%BC%9A%E8%AE%BF%E9%97%AE%E8%BF%99%E4%BA%9B%E5%AE%9E%E4%BE%8B%EF%BC%9F%E6%88%91%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%20Excel%20VBA%20%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20FreeMASTER%20%E5%AF%B9%E8%B1%A1%E6%9D%A5%E8%AF%BB%E5%8F%96%E5%92%8C%E5%86%99%E5%85%A5%E5%8F%98%E9%87%8F%E7%AD%89%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C%E9%82%A3%E4%B9%88%E5%AE%9E%E4%BE%8B%E5%90%8D%E7%A7%B0%E5%B0%B1%E4%BC%9A%E5%87%BA%E7%8E%B0%E4%B8%80%E4%BA%9B%E7%AE%80%E5%8D%95%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E5%A6%82%E6%9E%9C%E5%AE%83%E5%8F%AA%E6%98%AF%E8%BF%90%E8%A1%8C%E5%AE%9E%E4%BE%8B%EF%BC%8C%E4%BD%86%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E8%AE%BF%E9%97%AE%E5%AE%83%E4%BB%AC%EF%BC%8C%E9%82%A3%E4%B9%88%E8%AE%BF%E9%97%AE%E6%9D%83%E9%99%90%E5%8F%AF%E8%83%BD%E5%AD%98%E5%9C%A8%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%B0%9D%E8%AF%95%E7%9A%84%E5%AE%9E%E9%AA%8C%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E6%89%8B%E5%8A%A8%E8%BF%90%E8%A1%8C%20pcmaster.exe%20%E5%B9%B6%E7%BB%99%E5%AE%83%E4%B8%80%E4%BA%9B%E7%AE%80%E5%8D%95%E7%9A%84%E5%90%8D%E7%A7%B0%EF%BC%8C%E4%BE%8B%E5%A6%82%20A%20%E6%88%96%20B%E3%80%82%E4%B8%8D%E8%A6%81%E4%BD%BF%E7%94%A8%E4%BB%BB%E4%BD%95%E7%89%B9%E6%AE%8A%E5%AD%97%E7%AC%A6%E7%AD%89%E3%80%82%E7%84%B6%E5%90%8E%E5%9C%A8%20VBA%20%E8%84%9A%E6%9C%AC%E4%B8%AD%E4%BD%BF%E7%94%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E5%90%8D%E7%A7%B0%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E4%BB%A5%E7%AE%A1%E7%90%86%E5%91%98%E8%BA%AB%E4%BB%BD%E8%BF%90%E8%A1%8C%20Excel%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E5%B0%9D%E8%AF%95%E4%BD%8D%E4%BA%8E%E2%80%9Cc%3A%5CNXP%5CFreeMASTER%203.2%5CFreeMASTER%5Cexamples%5Cscripting%5CVisual%20Basic%20Application%20-%20Excel%E2%80%9D%E4%B8%AD%E7%9A%84%E7%AE%80%E5%8D%95%20Excel%20%E7%A4%BA%E4%BE%8B%E3%80%82%E5%AE%83%E4%BB%AC%E6%9C%89%E7%94%A8%E5%90%97%EF%BC%9F%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%3CBR%20%2F%3E%E7%B1%B3%E5%93%88%E5%B0%94%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1868165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%80%E4%B8%AA%20MATLAB%20%E8%84%9A%E6%9C%AC%E6%8E%A7%E5%88%B6%E4%B8%A4%E4%B8%AA%20FreeMaster%20%E5%AE%9E%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1868165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%8A%AA%E5%8A%9B%EF%BC%8CMichal%E3%80%82%3C%2FP%3E%3CP%3E1-%E6%88%91%E5%AE%89%E8%A3%85%E4%BA%863.2.3.2%E7%89%88%E6%9C%AC%EF%BC%8C%E9%80%80%E5%87%BAFreeMaster%E7%AA%97%E5%8F%A3%E7%9A%84%E9%97%AE%E9%A2%98%E5%BE%97%E5%88%B0%E4%BA%86%E8%A7%A3%E5%86%B3%E3%80%82%3C%2FP%3E%3CP%3E2-%E6%88%91%E9%87%87%E7%94%A8%E4%BA%86%E4%B8%BA%E7%89%B9%E5%AE%9A%E8%B7%AF%E5%BE%84%E4%B8%AD%E7%9A%84%E7%89%B9%E5%AE%9A%E5%AE%9E%E4%BE%8B%E6%8F%90%E4%BE%9B%20sharex%20%E5%90%8D%E7%A7%B0%E7%9A%84%E6%96%B9%E5%BC%8F%EF%BC%8C%E5%B0%B1%E5%83%8F%E4%B8%8A%E9%9D%A2%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%B8%80%E6%A0%B7%EF%BC%8C%E7%84%B6%E5%90%8E%E5%B0%86%E6%AD%A4%20sharex%20%E5%90%8D%E7%A7%B0%E4%BC%A0%E9%80%92%E7%BB%99%20GetAppObject%20()%20%E6%96%B9%E6%B3%95%EF%BC%8C%E8%BF%99%E7%A7%8D%E6%96%B9%E5%BC%8F%E5%8F%AF%E4%BB%A5%E4%B8%8E%20MATLAB%20%E8%84%9A%E6%9C%AC%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%E6%89%80%E4%BB%A5%E7%8E%B0%E5%9C%A8MATLAB%E7%9A%84%E9%97%AE%E9%A2%98%E5%B7%B2%E7%BB%8F%E8%A7%A3%E5%86%B3%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E5%BD%93%E5%AF%B9%20Excell%20%E6%89%A7%E8%A1%8C%E7%9B%B8%E5%90%8C%E6%93%8D%E4%BD%9C%E6%97%B6%EF%BC%8C%E5%AE%83%E6%97%A0%E6%B3%95%E6%89%BE%E5%88%B0%E4%B8%A4%E4%B8%AA%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E7%9A%84%20FreeMaster%20%E5%AE%9E%E4%BE%8B%EF%BC%8C%E8%80%8C%E6%98%AF%E6%89%93%E5%BC%80%E4%BA%86%E4%B8%A4%E4%B8%AA%E6%96%B0%E5%AE%9E%E4%BE%8B%EF%BC%8C%E4%B8%BA%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%3C%2FP%3E%3CP%3E%E8%89%BE%E5%93%88%E8%BF%88%E5%BE%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1866878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%80%E4%B8%AA%20MATLAB%20%E8%84%9A%E6%9C%AC%E6%8E%A7%E5%88%B6%E4%B8%A4%E4%B8%AA%20FreeMaster%20%E5%AE%9E%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1866878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E8%89%BE%E5%93%88%E8%BF%88%E5%BE%B7%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%2Fsharex%20%E9%80%89%E9%A1%B9%E5%90%8E%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%8F%82%E6%95%B0%E4%B8%8D%E6%98%AF%20pmp%20%E9%A1%B9%E7%9B%AE%E6%96%87%E4%BB%B6%E7%9A%84%E5%90%8D%E7%A7%B0%EF%BC%8C%E8%80%8C%E6%98%AF%E7%94%A8%E4%BA%8E%E8%AF%86%E5%88%AB%20mult.GetAppObject%20%E7%9A%84%E8%BF%90%E8%A1%8C%E5%AE%9E%E4%BE%8B%E7%9A%84%E5%90%8D%E7%A7%B0%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E4%B9%9F%E6%83%B3%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%88%99%E9%9C%80%E8%A6%81%E5%9C%A8%E5%90%8D%E7%A7%B0%E5%90%8E%E6%8C%87%E5%AE%9A%E5%AE%83%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A4%BA%E4%BE%8B%EF%BC%9A%3C%2FP%3E%0A%3CPRE%20translate%3D%22no%22%3Epcmaster.exe%20C%3A%5Cpath%5CSpdControl.pmp%26nbsp%3B%20%26nbsp%3B%20%2F%2F%20will%20just%20open%20the%20project%20file%3CBR%20%2F%3Epcmaster.exe%20%2Fsharex%20SPD%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%2F%2F%20will%20run%20the%20FreeMASTER%20named%20SPD%2C%20%3CBR%20%2F%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%26nbsp%3Bso%20you%20can%20attach%20to%20it%20using%26nbsp%3BGetAppObject(%22SPD%22)%3CBR%20%2F%3Epcmaster.exe%20%2Fsharex%20SPD%20C%3A%5Cpath%5CSpdControl.pmp%20%20%2F%2F%20will%20do%20both%3C%2FPRE%3E%0A%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%9C%A8%E6%89%80%E6%9C%89%E7%A4%BA%E4%BE%8B%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%9C%A8%20%2Fsharex%20%E9%80%89%E9%A1%B9%E5%90%8E%E5%8F%AA%E4%BC%A0%E9%80%92%E4%BA%86%E4%B8%80%E4%B8%AA%E5%8F%82%E6%95%B0%EF%BC%8C%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E5%AE%83%E5%BA%94%E8%AF%A5%E5%9C%A8%E4%B8%8D%E6%89%93%E5%BC%80%E4%BB%BB%E4%BD%95%E9%A1%B9%E7%9B%AE%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%90%AF%E5%8A%A8%20FreeMASTER%E3%80%82%E6%82%A8%E8%AF%B4%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%90%AF%E5%8A%A8%E5%90%8E%E7%AB%8B%E5%8D%B3%E5%85%B3%E9%97%AD...%E8%BF%99%E5%8F%AF%E8%83%BD%E8%A1%A8%E6%98%8E%E5%AE%89%E8%A3%85%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E6%82%A8%E8%83%BD%E7%A1%AE%E5%AE%9A%E6%82%A8%E8%BF%90%E8%A1%8C%E7%9A%84%E6%98%AF%203.2.3.2%20%E7%89%88%E6%9C%AC%E5%90%97%EF%BC%9F%EF%BC%88%E8%AF%B7%E5%8F%82%E9%98%85%E5%B8%AE%E5%8A%A9%2F%E5%85%B3%E4%BA%8E%E5%AF%B9%E8%AF%9D%E6%A1%86%EF%BC%89%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%8F%A6%E4%B8%80%E5%8F%B0%E7%94%B5%E8%84%91%E4%B8%8A%E5%B0%9D%E8%AF%95%E5%90%8C%E6%A0%B7%E7%9A%84%E6%93%8D%E4%BD%9C%E5%90%97%EF%BC%9F%3C%2FLI%3E%0A%3CLI%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%90%AF%E5%8A%A8%E2%80%9Cpcmaster.exe%E2%80%9D%E5%90%97%EF%BC%9F%E6%97%A0%E9%9C%80%E4%BB%BB%E4%BD%95%E5%8F%82%E6%95%B0%E5%8D%B3%E5%8F%AF%E6%9F%A5%E7%9C%8B%E5%AE%83%E6%98%AF%E5%90%A6%E8%83%BD%E5%A4%9F%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%EF%BC%9F%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%3CBR%20%2F%3E%E7%B1%B3%E5%93%88%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1863867%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%80%E4%B8%AA%20MATLAB%20%E8%84%9A%E6%9C%AC%E6%8E%A7%E5%88%B6%E4%B8%A4%E4%B8%AA%20FreeMaster%20%E5%AE%9E%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1863867%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E6%88%91%E4%BC%9A%E5%9C%A8%E5%8F%A6%E4%B8%80%E5%8F%B0%E7%94%B5%E8%84%91%E4%B8%8A%E5%B0%9D%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8D%E6%98%8E%E7%99%BD%E8%BF%99%E5%8F%A5%E8%AF%9D%EF%BC%9A%E2%80%9C%3CSPAN%3E%E6%97%A0%E8%AE%BA%E5%A6%82%E4%BD%95%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%E6%AD%A3%E7%A1%AE%E7%9A%84%E2%80%9C%2Fsharex%E2%80%9D%E9%80%89%E9%A1%B9%E6%89%8B%E5%8A%A8%E5%90%AF%E5%8A%A8%20FreeMASTER%EF%BC%8C%E9%82%A3%E4%B9%88%20VBA%20%E8%84%9A%E6%9C%AC%E5%B0%B1%E4%BC%9A%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%20-%20%E6%89%80%E4%BB%A5%E8%BF%99%E8%82%AF%E5%AE%9A%E4%B8%8E%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%E4%B8%8D%E5%90%8C%E3%80%82%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%9C%A8%E6%AD%A4%EF%BC%9A%E8%AF%B7%E5%B0%9D%E8%AF%95%E5%86%8D%E5%81%9A%E4%B8%80%E6%AC%A1%E5%AE%9E%E9%AA%8C%E5%B9%B6%E6%89%8B%E5%8A%A8%E5%90%AF%E5%8A%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E5%9C%A8%E5%AE%89%E8%A3%85%E4%B8%AD%E6%89%BE%E5%88%B0%20pcmaster.exe%20%E6%96%87%E4%BB%B6%E5%B9%B6%E4%BB%8E%E5%91%BD%E4%BB%A4%E8%A1%8C%E4%BD%BF%E7%94%A8%E5%8F%82%E6%95%B0%3CSTRONG%3E%2Fsharex%E2%80%9CA%E2%80%9D%3C%2FSTRONG%3E%E8%BF%90%E8%A1%8C%E5%AE%83%EF%BC%8C%E4%BD%BF%E7%94%A8%E5%8F%A6%E4%B8%80%E4%B8%AA%3CSTRONG%3E%E5%8F%82%E6%95%B0%20%2Fsharex%E2%80%9CB%E2%80%9D%E8%BF%90%E8%A1%8C%E5%AE%83%E3%80%82%3C%2FSTRONG%3E%E7%84%B6%E5%90%8E%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E2%80%9CA%E2%80%9D%E5%92%8C%E2%80%9CB%E2%80%9D%E5%90%8D%E7%A7%B0%E7%9A%84%E8%84%9A%E6%9C%AC%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%E7%AE%80%E5%8D%95%E5%9C%B0%E9%80%9A%E8%BF%87%20A%26amp%3BB%20%E9%87%8D%E5%91%BD%E5%90%8D%E5%AE%9E%E4%BE%8B%E8%BF%98%E6%98%AF%E5%85%B6%E4%BB%96%E4%BB%80%E4%B9%88%EF%BC%9F%E6%88%91%E6%84%9F%E8%A7%89%E6%88%91%E8%AF%AF%E8%A7%A3%E4%BA%86%E6%9F%90%E4%BB%B6%E4%BA%8B%E3%80%82%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%AA%2Fsharex%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%90%88%E4%BD%9C%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1861595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%80%E4%B8%AA%20MATLAB%20%E8%84%9A%E6%9C%AC%E6%8E%A7%E5%88%B6%E4%B8%A4%E4%B8%AA%20FreeMaster%20%E5%AE%9E%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1861595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E6%88%91%E4%BC%9A%E5%B0%9D%E8%AF%95%E8%BF%99%E4%B8%AA%EF%BC%8C%E4%B9%9F%E7%AD%89%E4%BD%A0%E5%B0%9D%E8%AF%95%E3%80%82%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1860491%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%80%E4%B8%AA%20MATLAB%20%E8%84%9A%E6%9C%AC%E6%8E%A7%E5%88%B6%E4%B8%A4%E4%B8%AA%20FreeMaster%20%E5%AE%9E%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1860491%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E8%89%BE%E5%93%88%E8%BF%88%E5%BE%B7%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%B0%86%E4%BD%BF%E7%94%A8%2032%20%E4%BD%8D%20Excel%20%E9%87%8D%E8%AF%95%EF%BC%8C%E8%BF%99%E9%9C%80%E8%A6%81%E4%B8%80%E4%BA%9B%E6%97%B6%E9%97%B4%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E5%86%8D%E5%81%9A%E4%B8%80%E6%AC%A1%E5%AE%9E%E9%AA%8C%E5%B9%B6%E6%89%8B%E5%8A%A8%E5%90%AF%E5%8A%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E5%9C%A8%E5%AE%89%E8%A3%85%E4%B8%AD%E6%89%BE%E5%88%B0%20pcmaster.exe%20%E6%96%87%E4%BB%B6%E5%B9%B6%E4%BB%8E%E5%91%BD%E4%BB%A4%E8%A1%8C%E4%BD%BF%E7%94%A8%E5%8F%82%E6%95%B0%3CSTRONG%3E%2Fsharex%E2%80%9CA%E2%80%9D%3C%2FSTRONG%3E%E8%BF%90%E8%A1%8C%E5%AE%83%EF%BC%8C%E4%BD%BF%E7%94%A8%E5%8F%A6%E4%B8%80%E4%B8%AA%3CSTRONG%3E%E5%8F%82%E6%95%B0%20%2Fsharex%E2%80%9CB%E2%80%9D%E8%BF%90%E8%A1%8C%E5%AE%83%E3%80%82%3C%2FSTRONG%3E%E7%84%B6%E5%90%8E%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E2%80%9CA%E2%80%9D%E5%92%8C%E2%80%9CB%E2%80%9D%E5%90%8D%E7%A7%B0%E7%9A%84%E8%84%9A%E6%9C%AC%E3%80%82%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E9%97%AE%E9%A2%98%E6%98%AF%E6%82%A8%E7%9A%84%20Excel%20%E6%98%AF%E5%90%A6%E4%BC%9A%E6%89%BE%E5%88%B0%E4%B8%A4%E4%B8%AA%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E7%9A%84%E5%AE%9E%E4%BE%8B%EF%BC%8C%E6%88%96%E8%80%85%E5%AE%83%E6%98%AF%E5%90%A6%E4%BC%9A%E5%90%AF%E5%8A%A8%E5%8F%A6%E5%A4%96%E4%B8%A4%E4%B8%AA%E6%96%B0%E5%AE%9E%E4%BE%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%90%88%E4%BD%9C%EF%BC%8C%3CBR%20%2F%3E%E7%B1%B3%E5%93%88%E5%B0%94%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1859931%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%80%E4%B8%AA%20MATLAB%20%E8%84%9A%E6%9C%AC%E6%8E%A7%E5%88%B6%E4%B8%A4%E4%B8%AA%20FreeMaster%20%E5%AE%9E%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1859931%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%BD%93%E6%88%91%E5%AE%8C%E5%85%A8%E6%8C%89%E7%85%A7%E6%82%A8%E7%9A%84%E4%BB%A3%E7%A0%81%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%E4%B8%94%E4%B8%8D%E5%81%9A%E4%BB%BB%E4%BD%95%E6%9B%B4%E6%94%B9%E6%97%B6%EF%BC%8C%E5%90%8C%E4%B8%80%E8%A1%8C%E4%B8%AD%E5%87%BA%E7%8E%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8Ca%EF%BC%86b%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%97%A0%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E8%BF%90%E8%A1%8C%20register.bat%20%E6%97%B6%EF%BC%8C%E5%AE%83%E4%BC%9A%E6%9A%82%E6%97%B6%E5%87%BA%E7%8E%B0%E9%BB%91%E8%89%B2%E7%AA%97%E5%8F%A3%E7%84%B6%E5%90%8E%E6%B6%88%E5%A4%B1%E3%80%82%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E8%BF%99%E6%98%AF%E4%BB%80%E4%B9%88%E6%84%8F%E6%80%9D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84Excel%E6%98%AF32%E4%BD%8D%E7%9A%84%E3%80%82%E7%9C%8B%E6%9D%A5%E8%BF%99%E5%B0%B1%E6%98%AF%E9%80%A0%E6%88%90%E5%B7%AE%E5%BC%82%E7%9A%84%E5%8E%9F%E5%9B%A0%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1859673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%80%E4%B8%AA%20MATLAB%20%E8%84%9A%E6%9C%AC%E6%8E%A7%E5%88%B6%E4%B8%A4%E4%B8%AA%20FreeMaster%20%E5%AE%9E%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1859673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E8%83%BD%E5%B0%9D%E8%AF%95%E4%B8%80%E4%B8%8B%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%E5%90%97%EF%BC%9F%E5%8F%AA%E6%98%AF%E4%B8%BA%E4%BA%86%E6%AF%94%E8%BE%83%E8%A1%8C%E4%B8%BA%E3%80%82%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C32%20%E4%BD%8D%E5%92%8C%2064%20%E4%BD%8D%E7%89%88%E6%9C%AC%E7%9A%84%20Excel%20%E5%8F%AF%E8%83%BD%E5%AD%98%E5%9C%A8%E5%B7%AE%E5%BC%82%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E6%B5%8B%E8%AF%95%2064%20%E4%BD%8D%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E8%BF%98%E5%8F%AF%E4%BB%A5%E6%94%BE%E7%BD%AE%E6%96%AD%E7%82%B9%E6%9D%A5%E6%A3%80%E6%9F%A5%20a%20%E5%92%8C%20b%20%E5%8F%98%E9%87%8F%E6%98%AF%E5%90%A6%E7%A1%AE%E5%AE%9E%E8%AE%BE%E7%BD%AE%E4%B8%BA%E2%80%9C%E6%97%A0%E2%80%9D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%B8%BA%E4%BA%86%E7%A1%AE%E4%BF%9D%E5%AE%89%E8%A3%85%E6%AD%A3%E7%A1%AE%EF%BC%8C%E8%AF%B7%E8%BF%90%E8%A1%8C%E2%80%9Cregister.bat%E2%80%9D%E4%BB%A5%E7%AE%A1%E7%90%86%E5%91%98%E8%BA%AB%E4%BB%BD%E8%BF%9B%E5%85%A5%20FreeMASTER%20%E5%AE%89%E8%A3%85%E6%96%87%E4%BB%B6%E5%A4%B9%20(c%3A%5CNXP%5CFreeMASTER%203.2%5CFreeMASTER%5Cregister.bat)%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%3CBR%20%2F%3E%E7%B1%B3%E5%93%88%E5%B0%94%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1859059%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%80%E4%B8%AA%20MATLAB%20%E8%84%9A%E6%9C%AC%E6%8E%A7%E5%88%B6%E4%B8%A4%E4%B8%AA%20FreeMaster%20%E5%AE%9E%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1859059%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E6%88%91%E7%AD%89%E4%BD%A0%E8%BF%9B%E4%B8%80%E6%AD%A5%E8%B0%83%E6%9F%A5%E6%AD%A4%E4%BA%8B%E3%80%82%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%8A%AA%E5%8A%9B%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20Visual%20Basic%20%E9%80%9A%E8%BF%87%20Excel%20%E6%9D%A5%E5%AE%9E%E7%8E%B0%E5%AE%83%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%88%91%E4%BB%8E%E4%BB%A5%E4%B8%8B%E4%BB%A3%E7%A0%81%E5%BC%80%E5%A7%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%AD%90%20mmult_test()%3CBR%20%2F%3E%20Dim%20a%20As%20McbPcm%3CBR%20%2F%3E%20Dim%20b%20%E4%BD%9C%E4%B8%BA%20McbPcm%3CBR%20%2F%3E%20Dim%20mult%20%E4%BD%9C%E4%B8%BA%20McbMult%3C%2FP%3E%3CP%3E%E8%AE%BE%E7%BD%AE%20mult%20%3D%20New%20McbMult%3CBR%20%2F%3E%E8%AE%BE%E7%BD%AE%20a%20%3D%20mult.GetAppObject(%22A%22)%3CBR%20%2F%3E%E8%AE%BE%E7%BD%AE%20b%20%3D%20mult.GetAppObject(%22B%22)%3C%2FP%3E%3CP%3EDim%20bSucc%20%E4%BD%9C%E4%B8%BA%E5%B8%83%E5%B0%94%E5%80%BC%3C%2FP%3E%3CP%3E'ReadVariable%20%E4%BD%BF%E7%94%A8%E5%BD%93%E5%89%8D%E9%A1%B9%E7%9B%AE%E4%B8%AD%E7%9A%84%20FreeMASTER%20%E5%8F%98%E9%87%8F%E5%AF%B9%E8%B1%A1%E3%80%82%E4%BD%BF%E7%94%A8%3CBR%20%2F%3E'ReadUIntVariable%20%E4%BD%BF%E7%94%A8%E7%AC%A6%E5%8F%B7%E5%90%8D%E7%A7%B0%E7%9B%B4%E6%8E%A5%E8%AE%BF%E9%97%AE%E5%86%85%E5%AD%98%E3%80%82%3CBR%20%2F%3E%E8%AE%BE%E7%BD%AE%20bSucc%20%3D%20a.ReadVariable(%22SPEED_CMD%22%2C%20vValue%2C%20tValue%2C%20bsRetMsg)%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%20bSucc%20%E5%88%99%3CBR%20%2F%3Esht.Range(%22B1%22).Value%20%3D%20vValue%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E7%BB%93%E6%9D%9F%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%20b.ReadVariable(%22TrqCtrlSwitch%22%2C%20%22B3%22)%20%E5%88%99%3CBR%20%2F%3EMsgBox%20(%22%E6%9D%A5%E8%87%AA%E5%AE%9E%E4%BE%8B%20B%20%E7%9A%84%E5%8F%98%E9%87%8F%20%22%20%2B%20t2)%3CBR%20%2F%3E%E5%88%AB%E7%9A%84%3CBR%20%2F%3EMsgBox%20(%22%E4%BB%8E%E5%AE%9E%E4%BE%8B%20B%20%E8%AF%BB%E5%8F%96%E6%97%B6%E5%87%BA%E9%94%99%EF%BC%9A%22%20%2B%20m2)%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E7%BB%93%E6%9D%9F%3CBR%20%2F%3E%E7%BB%93%E6%9D%9F%E5%AD%90%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E8%BF%99%E9%87%8C%E7%9C%8B%E5%88%B0%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FFreeMASTER%2FMultiple-instances-using-ActiveX-in-VB%2Ftd-p%2F1340033%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FFreeMASTER%2FMultiple-instances-using-ActiveX-in-VB%2Ftd-p%2F1340033%3C%2FA%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E6%88%91%E5%9C%A8%E6%AD%A4%E8%A1%8C%E6%94%B6%E5%88%B0%E7%BC%96%E8%AF%91%E5%99%A8%E9%94%99%E8%AF%AF%EF%BC%9ASet%20bSucc%20%3D%20a.ReadVariable(%22SPEED_CMD%22%2C%20vValue%2C%20tValue%2C%20bsRetMsg)%20%E9%94%99%E8%AF%AF%E6%8F%90%E7%A4%BA%E4%B8%BA%EF%BC%9A%E2%80%9CObject%20Required%E2%80%9D%EF%BC%8C%E8%80%8C%E5%BD%93%E6%88%91%E5%88%A0%E9%99%A4%E2%80%9CSet%E2%80%9D%E6%97%B6%EF%BC%8C%E5%AE%83%E6%98%BE%E7%A4%BA%EF%BC%9A%E2%80%9C%E6%9C%AA%E8%AE%BE%E7%BD%AE%E5%AF%B9%E8%B1%A1%E5%8F%98%E9%87%8F%E6%88%96%E5%9D%97%E5%8F%98%E9%87%8F%E2%80%9D%E6%88%91%E8%AE%A4%E4%B8%BA%E5%AE%83%E4%B9%9F%E7%9C%8B%E4%B8%8D%E5%88%B0%20GetAppObject%20%E8%BF%94%E5%9B%9E%E7%9A%84%E5%AF%B9%E8%B1%A1%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E4%B9%8B%E5%89%8D%E5%B7%B2%E7%BB%8F%E6%B5%8B%E8%AF%95%E8%BF%87%E4%BD%BF%E7%94%A8%20Excell%20%E6%8E%A7%E5%88%B6%E4%B8%A4%E4%B8%AA%20FreeMaster%20%E5%AE%9E%E4%BE%8B%EF%BC%8C%E8%AF%B7%E5%B8%AE%E5%8A%A9%E6%88%91%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%89%BE%E5%93%88%E8%BF%88%E5%BE%B7%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1858813%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%80%9A%E8%BF%87%E4%B8%80%E4%B8%AA%20MATLAB%20%E8%84%9A%E6%9C%AC%E6%8E%A7%E5%88%B6%E4%B8%A4%E4%B8%AA%20FreeMaster%20%E5%AE%9E%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1858813%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E8%89%BE%E5%93%88%E8%BF%88%E5%BE%B7%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EMCB.MULT%20%E6%98%AF%E4%B8%80%E4%B8%AA%E5%AF%B9%E8%B1%A1%E7%9A%84%E6%A0%87%E8%AF%86%E7%AC%A6%EF%BC%8C%E5%8F%AF%E5%B8%AE%E5%8A%A9%E6%82%A8%E7%AE%A1%E7%90%86%20FreeMASTER%20%E7%9A%84%E5%A4%9A%E4%B8%AA%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E7%9A%84%E5%AE%9E%E4%BE%8B%E3%80%82%E5%AE%83%E5%8F%AA%E6%9C%89%E4%B8%80%E4%B8%AA%E6%96%B9%E6%B3%95%20GetAppObject%EF%BC%8C%E4%BD%86%E7%94%A8%E9%80%94%E9%9D%9E%E5%B8%B8%E5%B9%BF%E6%B3%9B%E3%80%82%E8%AF%B7%E9%98%85%E8%AF%BB%E7%94%A8%E6%88%B7%E6%89%8B%E5%86%8C%E7%AC%AC%206.9%20%E8%8A%82%E4%BB%A5%E4%BA%86%E8%A7%A3%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E4%BD%BF%E7%94%A8%20GetAppObject%20%E6%82%A8%E5%8F%AF%E4%BB%A5%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3E%E8%8E%B7%E5%8F%96%E6%8E%A5%E5%8F%A3%E5%AF%B9%E8%B1%A1%E4%BD%9C%E4%B8%BA%20FreeMASTER%20%E7%9A%84%E2%80%9C%E5%91%BD%E5%90%8D%E2%80%9D%E8%BF%90%E8%A1%8C%E5%AE%9E%E4%BE%8B%E7%9A%84%20ActiveX%20%E6%8E%A5%E5%8F%A3%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%E5%B0%9A%E6%9C%AA%E8%BF%90%E8%A1%8C%EF%BC%8C%E5%88%99%E8%BF%90%E8%A1%8C%E5%91%BD%E5%90%8D%E5%AE%9E%E4%BE%8B%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3E%E8%BF%90%E8%A1%8C%E5%91%BD%E5%90%8D%E5%AE%9E%E4%BE%8B%E5%B9%B6%E5%8A%A0%E8%BD%BD%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%3E%E6%8E%A7%E5%88%B6%E4%B8%A4%E4%B8%AA%E6%88%96%E5%A4%9A%E4%B8%AA%20FreeMASTER%20%E5%AE%9E%E4%BE%8B%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%3CSPAN%3E%E9%80%9A%E8%BF%87%E5%90%AF%E5%8A%A8%20pcmaster.exe%20%E8%BF%9B%E7%A8%8B%E6%89%8B%E5%8A%A8%E8%BF%90%E8%A1%8C%E5%AE%9E%E4%BE%8B%20A%E3%80%82%E4%BD%BF%E7%94%A8%E5%91%BD%E4%BB%A4%E8%A1%8C%E5%8F%82%E6%95%B0%E2%80%9C%2Fsharex%20A%E2%80%9D%E4%B8%BA%E5%85%B6%E5%91%BD%E5%90%8D%E3%80%82%E5%BD%93%20FreeMASTER%20%E5%90%AF%E5%8A%A8%E6%97%B6%EF%BC%8C%E9%85%8D%E7%BD%AE%E6%9D%BF%E8%BF%9E%E6%8E%A5%EF%BC%8C%E6%89%93%E5%BC%80%E9%A1%B9%E7%9B%AE%E7%AD%89%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3E%E7%B1%BB%E4%BC%BC%E5%9C%B0%EF%BC%8C%E8%BF%90%E8%A1%8C%E5%90%8D%E4%B8%BA%E2%80%9CB%E2%80%9D%E7%9A%84%E5%AE%9E%E4%BE%8B%E5%B9%B6%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%AC%AC%E4%BA%8C%E5%9D%97%E6%9D%BF%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3E%E5%9C%A8%20matlab%20%E4%B8%AD%EF%BC%8C%E8%B0%83%E7%94%A8%20%3C%2FSPAN%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3EpcmA%20%3D%20mult.GetAppObject(%E2%80%9CA%E2%80%9D)%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EpcmB%20%3D%20mult.GetAppObject(%E2%80%9CB%E2%80%9D)%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3E%E7%8E%B0%E5%9C%A8%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E6%AF%8F%E4%B8%AA%E5%AF%B9%E8%B1%A1%E6%9D%A5%E8%AF%BB%E5%8F%96%E5%8F%98%E9%87%8F%E5%B9%B6%E6%89%A7%E8%A1%8C%E7%89%B9%E5%AE%9A%E4%BA%8E%E6%AF%8F%E4%B8%AA%E6%9D%BF%E7%9A%84%E5%85%B6%E4%BB%96%E6%8E%A7%E5%88%B6%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CSPAN%3E%E6%88%96%E8%80%85%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%86%E9%A1%B9%E7%9B%AE%E4%BF%9D%E5%AD%98%E4%B8%BA%20projectA.pcmx%20%E5%92%8C%20projectB.pcmx%E3%80%82%E7%A1%AE%E4%BF%9D%E9%80%89%E4%B8%AD%E2%80%9C%E5%B0%86%E8%AE%BE%E7%BD%AE%E4%BF%9D%E5%AD%98%E5%88%B0%E9%A1%B9%E7%9B%AE%E6%96%87%E4%BB%B6%E2%80%9D%EF%BC%8C%E4%BB%A5%E4%BE%BF%E4%BF%9D%E5%AD%98%E9%80%9A%E4%BF%A1%E8%AE%BE%E7%BD%AE%E3%80%82%E7%84%B6%E5%90%8E%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%86%E6%AF%8F%E4%B8%AA%E9%A1%B9%E7%9B%AE%E7%9A%84%E5%90%8D%E7%A7%B0%E4%BD%9C%E4%B8%BA%20GetAppObject%20%E7%9A%84%E7%AC%AC%203%20%E4%B8%AA%E5%8F%82%E6%95%B0%E4%BC%A0%E9%80%92%EF%BC%8C%E5%AE%83%E5%B0%86%E8%B4%9F%E8%B4%A3%E8%BF%90%E8%A1%8C%20FreeMASTER%20%E5%B9%B6%E8%87%AA%E5%8A%A8%E5%8A%A0%E8%BD%BD%E9%A1%B9%E7%9B%AE%E4%BB%A5%E5%8F%8A%E9%80%9A%E4%BF%A1%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%8F%A6%E4%B8%80%E7%A7%8D%E9%80%89%E6%8B%A9%E6%98%AF%E6%8C%89%E7%85%A7%E4%B8%8A%E9%9D%A2%E6%89%80%E7%A4%BA%E4%BB%8E%20Matlab%20%E5%90%AF%E5%8A%A8%E5%AE%9E%E4%BE%8B%20A%20%E5%92%8C%20B%EF%BC%88%E6%97%A0%E9%9C%80%E6%89%93%E5%BC%80%E9%A1%B9%E7%9B%AE%EF%BC%89%EF%BC%8C%E7%84%B6%E5%90%8E%E4%BD%BF%E7%94%A8%E5%9C%A8%20pcmA%20%E5%92%8C%20pcmB%20%E5%AF%B9%E8%B1%A1%E4%B8%8A%E6%89%A7%E8%A1%8C%E7%9A%84%20StartComm%20%E5%92%8C%20OpenProject%20%E6%96%B9%E6%B3%95%E4%BB%8E%E8%84%9A%E6%9C%AC%E5%8D%8F%E8%B0%83%E6%89%80%E6%9C%89%E5%86%85%E5%AE%B9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3E%E7%B1%B3%E5%93%88%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E
