Code generation is too slow
2,334 次查看
Rahul_Kalvem
Greetings,
For some strange reason the code generation is taking too long, I have been encountering the issue from the past two days, I used the same Simulink model which I was using before, the code used to get generated and downloaded in less than a minute but now the same model is taking around 13 mins and sometimes even 19 to 25 mins. I have not changed any code generation settings.
Did anybody encounter the same issue?
Any particular reason for this?
标记 (1)
0 回复数
