CRC Evaluation using direct memory addressing
973件の閲覧回数
embedded_dan73
Hello all.
I'm working with S32K358 MCU, MBD Toolbox v1.6.0 and Matlab R2024a.
I know that Crc module isn't supported by the toolbox, so I configured the .mex file of the project in order to generate the RTD configuration suitable for my application, including Crc module, and then I wrote a Matlab function in order to manually call, as custom code, the "Crc_SetChannelCalculate" function.
This works fine and I can evaluate correctlty the CRC over a data streaming like an array.
Now what I would like to do is to evaluate the CRC on an area of memory, using directly the memory address as data input. If I write the code "manually" using S32DS IDE (outside Matlab), the code looks like this:
//--- code start
uint32 CrcResult;
uint8 *data;
data = (uint8 *)0x40A1F0; //arbitrary address chosen for starting calculation
CrcResult = Crc_SetChannelCalculate(CRC_LOGIC_CHANNEL_2, data, 16, 0, TRUE);
//in this way I calculate the CRC of 16 byte, with starting value = 0, read directly in flash starting from address 0x40A1F0
Of course, before this, I initialized the logic channel CRC_LOGIC_CHANNEL_2 with the properties suitable for my application.
This code works fine but I'm not able to "translate" it on Matlab, because I didn't find a suitable way for make a direct memory addressing (and, if I'm not wrong, Matlab doesn't support this possibility).
I would please ask you if someone has an idea on how to face this matter.
Thansk in advance for your help and support.
0 返答(返信)
%3CLINGO-SUB%20id%3D%22lingo-sub-2266820%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%9B%B4%E6%8E%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E6%8C%87%E5%AE%9A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FCRC%E8%A9%95%E4%BE%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266820%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%9A%86%E3%81%95%E3%82%93%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%20S32K358%20MCU%E3%80%81MBD%20Toolbox%20v1.6.0%E3%80%81Matlab%20R2024a%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ECrc%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AF%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A7%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81.mex%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%80%81Crc%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E5%90%AB%E3%82%80%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E9%81%A9%E3%81%97%E3%81%9F%20RTD%20%E6%A7%8B%E6%88%90%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AB%E3%80%81%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E3%81%97%E3%81%A6%20%22Crc_SetChannelCalculate%22%20%E9%96%A2%E6%95%B0%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%9F%E3%82%81%E3%81%AE%20Matlab%20%E9%96%A2%E6%95%B0%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%80%81%E9%85%8D%E5%88%97%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E4%B8%8A%E3%81%AECRC%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E8%A9%95%E4%BE%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%82%84%E3%82%8A%E3%81%9F%E3%81%84%E3%81%AE%E3%81%AF%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E3%83%87%E3%83%BC%E3%82%BF%E5%85%A5%E5%8A%9B%E3%81%A8%E3%81%97%E3%81%A6%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E9%A0%98%E5%9F%9F%E3%81%AE%20CRC%20%E3%82%92%E8%A9%95%E4%BE%A1%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82S32DS%20IDEs%20(Matlab%20%E5%A4%96%E9%83%A8)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%80%8C%E6%89%8B%E5%8B%95%E3%81%A7%E3%80%8D%E8%A8%98%E8%BF%B0%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%2F%2F---%20%E3%82%B3%E3%83%BC%E3%83%89%E9%96%8B%E5%A7%8B%3C%2FP%3E%3CP%3Euint32%20CrcResult%3B%3C%2FP%3E%3CP%3Euint8%20*%E3%83%87%E3%83%BC%E3%82%BF%3B%3C%2FP%3E%3CP%3Edata%20%3D%20(uint8%20*)0x40A1F0%3B%20%2F%2F%E8%A8%88%E7%AE%97%E9%96%8B%E5%A7%8B%E6%99%82%E3%81%AB%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%9F%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3C%2FP%3E%3CP%3ECrcResult%20%3D%20Crc_SetChannelCalculate(CRC_LOGIC_CHANNEL_2%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%80%8116%E3%80%810%E3%80%81TRUE)%3B%3C%2FP%3E%3CP%3E%2F%2F%E3%81%93%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E3%80%81%E9%96%8B%E5%A7%8B%E5%80%A4%20%3D%200%20%E3%81%A7%2016%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%20CRC%20%E3%82%92%E8%A8%88%E7%AE%97%E3%81%97%E3%80%81%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x40A1F0%20%E3%81%8B%E3%82%89%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E7%9B%B4%E6%8E%A5%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%2F%2F---%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%A1%E3%82%8D%E3%82%93%E3%80%81%E3%81%9D%E3%81%AE%E5%89%8D%E3%81%AB%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E9%81%A9%E3%81%97%E3%81%9F%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20CRC_LOGIC_CHANNEL_2%20%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E7%9B%B4%E6%8E%A5%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E6%8C%87%E5%AE%9A%E3%82%92%E8%A1%8C%E3%81%86%E9%81%A9%E5%88%87%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81Matlab%20%E3%81%A7%E3%80%8C%E5%A4%89%E6%8F%9B%E3%80%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%81%BE%E3%81%9F%E3%80%81%E7%A7%81%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%80%81Matlab%20%E3%81%AF%E3%81%93%E3%81%AE%E5%8F%AF%E8%83%BD%E6%80%A7%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93)%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%9E%E3%82%BF%E3%83%BC%E3%81%AB%E3%81%A9%E3%81%86%E5%AF%BE%E5%87%A6%E3%81%99%E3%81%B9%E3%81%8D%E3%81%8B%E3%80%81%E8%AA%B0%E3%81%8B%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%82%92%E3%81%8A%E6%8C%81%E3%81%A1%E3%81%AE%E6%96%B9%E3%81%8C%E3%81%84%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%81%8A%E4%BC%BA%E3%81%84%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%A8%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
