Build error for S32k142 using MBDT 4.2.0
1,259件の閲覧回数
sganesh1
I am trying to deploy a model on the S32k142EVB with MBDT 4.2.0 and I was running into the following build error.
gmake: *** No rule to make target `libecatinterface.a.lib', needed by `BMS_NXP_6s16p_EV.elf'. Stop. ### Build procedure for BMS_NXP_6s16p_EV aborted due to an error.
I am able to build all the required object files, but I am stuck at this stage for the ELF generation. Does anyone have any suggestions on how I can workaround this error?
0 返答(返信)
