About MTRCKTSPNZVM128_SW.exe setup.
2,328 次查看
xinquanzuo
hi, I have a problem when i setup the MTRCKTSPNZVM128_SW.exe. It showed up a window like this:捕获6.PNG
please help me, thanks!
标记 (1)
2,163 次查看
petrfajmon-b173
Hi dumitrupopa, xinquanzuo,
  it should be an issue on www.nxp.com . The AMMCLIB package for S12ZVM platform should be available .
I will check this issue with NXP web admins.
Thanks for raising this finding,
Petr
2,163 次查看
Daniel_Popa
Hi xinquanzuo‌,
I confirm your issue. It seems the AMMCLIB files can't be found.
Hi petrfajmon-b17364‌,
When trying to install the MTRCKTSPNZVM128 Software if we keep the AMMCLIB selection ON, the installer fails to copy all the files.
It returns:
Seems like it can't find out the AMMCLIB files. Do you know why?
BTW, it seems the AMMCLIB for ZVM is no longer available on the website: Automotive Math and Motor Control Library Set|NXP
If the customer wants to use a separate AMMCLIB install what version should we use.
