_time_delay_ticks hangs application with multiple Clock Configuration (MQX Lite Processor Expert Kinetis L KL24)
762 次查看
mroczeks
I have a project based on Kinetis L (KL24) device. I am using ProcessorExpert for drivers with MQX Lite as a PE driver too.
In my task loop I use _time_delay_ticks function call to wait for some time.
It all works OK if I have only one Clock Configuration created in CPU driver.
If I add second Clock Configuration the software execution reaches _time_delay_ticks function and hangs in Idle Task forever.
I does not matter if I ever use the second Clock Configuration or if this Clock Configuration is different from the first one.
If I delete _time_delay_ticks function call it all works OK.
WTF?
0 回复数
