sscanf Inconsistencies
1,754件の閲覧回数
weblar
I'm trying to use the MQX sscanf implementation however I'm coming up with some issues.
I have the following function call...
char * key = (char *)calloc(32, sizeof(char));char * value = (char *)calloc(32, sizeof(char));int_32 matches = sscanf("Enabled = Y", "%[^=]=%s", key, value);// matches = 0// key = nothing// value = nothing
 An identical function call from Visual C returns 2 and both key and value contain "Enabled" and "Y" respectively.
Am I missing something?
1,591件の閲覧回数
c0170
Senior Contributor III
Hi kwebster83,
unfortunately, the feature you tested ( %[ ] array of characters) is not implemented in MQXs' sscanf. This format might be implemented in the future MQX release. Thank you for your input!
MartinK
1,592件の閲覧回数
c0170
Hi kwebster83,
MartinK
