rtcs stack
rtcs stack
serhatitu
Is there a way to use rtcs stack indepentendly for tcp/ip communication without MQX library, i mean without RTOS?
Tags (2)
Martin_
I'm afraid not, it would be very difficult to remove OS-dependent interface from RTCS.
For a standalone tcp/ip stack, you should better look to FNET tcp/ip stack: http://fnet.sourceforge.net/
serhatitu
Thanks for quick reply .
Is there any example for using fnet stack with processor expert?
c0170
Senior Contributor III
Hello serhatitu,
I believe there is not, import FNET to your application without using PE.
c0170
