new ipcfg.c in MQX 4.1
706 次查看
huishao2
hi -
I found that IPCFG_default_xxx that were defined in rtcs\source\if\ipcfg.c are removed in MQX 4.1. My application has compiler errors on it, is there a way to resolve  it?
IPCFG_default_enet_device = DEMOCFG_DEFAULT_DEVICE;
IPCFG_default_ip_address = ENET_IPADDR;
IPCFG_default_ip_mask = ENET_IPMASK;
IPCFG_default_ip_gateway = ENET_IPGATEWAY
thanks!
Hui
613 次查看
soledad
Hi Hui Shao,
Please check the below thread, I hope this helps :smileywink:
K60F Demo Doesn't Work for MQX 4.0
Sol
