mqx for k63?
mqx for k63?
1,179 次查看
bonzo
Can the K64 version of MQX run without any modifications on the K63?
I realize the tamper detection is not supported, but are there any other gotcha's?
--Brad
标记 (3)
1,039 次查看
DavidS
Hi Brad,
Should be able to grab the MQX4.1 for FRDM-K64 and use the BSPCloningWizard to create new BSP for K63.  Then use PE to change the CPU to K63.
David
