mfs_init.c
mfs_init.c
729 次查看
vipako
Please correct in mfs_init.c from line 1114 to 1133, there are MFS_IOCTL_XXX constants which are no longer defined. Every new update of MQX I have to overwrite it to IO_IOCTL_XXX.
Patrik
标记 (1)
618 次查看
RadekS
Thank you for your bug report. Yes, you are right.
MFS_IOCTL_DELETE_FILE has to be replaced by IO_IOCTL_DELETE_FILE. The same for others IOCTL commands in this section (_io_mfs_ioctl(),#if MFSCFG_READ_ONLY)
It is know issue and it was already fixed in current developing version. It will be released in next MQX version (probably MQX 4.2)
RadekS
