how to write on usb in host mode?
1,015 次查看
Abil
hi all,
am using mqx 4.2 usb v2 stack ....can i use fwrite to write on usb?
942 次查看
soledad
hello,
please check the mfs_usb example, located at the path C:\Freescale\Freescale_MQX_4_2\mfs\examples\mfs_usb
This example illustrates the usage of USB host, MFS and Shell API to deal with the USB memory stick. The application example allows user to perform a set of commands with USB memory stick through the terminal output. This including creating and deleting files, writing to and read reading from files as well as manipulation of directory.
Sol
