how to send bulk data from serial to network
1,491件の閲覧回数
sheebad
hai,
 i am trying to send bulk data from serial to network by using serial<>telnet eaxmple program available in the MQX3.3,but most of the data is missing while i receiving in the client .i enabled the intterupt based serial ,increased the serial as well as telnet buffer size .it doesn't work .please give any solution .i tried dirctly with my pc and board then also the same problem is there.from network to serial side it is getting properly,the opposite direction making the problem.hope some one will help in this matter...
i am using evb-mcf52235 ,Mqx3.3 and code warrior  v7.1
                                                          thanks
614件の閲覧回数
JuroV
Hello.
   Can you implement data counter on both sides to find if you read / send all the data?
