how to schedule tasks from ISR?
1,163 次查看
Abil
hi,
Am working on FRDMk64f board with code warrior 10.6 and MQX 4.2.RTOS....can anyone suggest how to schedule tasks from ISR....am using HARDWARE interrupts and i want to schedule my task which is Priority based pre-empative scheduling..:smileyconfused:
1,015 次查看
soledad
Please check the below threads and please let me know if this helps!!
K60 and MQX installed ISR not called, why?
MQX application ISR help
How to Install New Hardware Intrerrupts in MQX
Sol
1,015 次查看
Abil
thanks soledad.........actually am using hardware interrupt and based on
that i want to schedule my task....my task is getting ready and active
twice (second task in the code)...and after that it gets terminated or
destroyed...i have not called taskdestroy() anywhere in my program...i am
attaching my code could u suggest wat i wrong ? and how to make it in
continuous executed depending on hardware interrupt..
On Thu, Dec 3, 2015 at 2:39 AM, soledad <admin@community.freescale.com>
