how to pass argument values to one task to another task
1,380 次查看
sudhakarp
hi..
     I want to pass value's from one task to another task. how to do this things..?
example: in one variable char variable=10;  i want to print this value to another task. and also my tasks are "MQX_AUTO_START_TASK". give some simple example code. i want to pass string value also.
regards,
sudhakar
4 回复数
1,151 次查看
matthewkendall
Intertask messages. In the MQX RTOS Reference Manual (MQXRM) see the _msgq_* functions. There is a example code in the description of the _msgq_send() function. There is also a full example program in Freescale_MQX_4_1\mqx\examples\msg\
1,151 次查看
sudhakarp
thank you matthew...
1,151 次查看
seandema
A quick way is to just make those global variables. But probably a safer way is to use something like messages. Light weight messages (LWMSG) are part of MQX and can be found in MQX_User_Guide.pdf and MQX_Reference_Manual.pdf in your MQX install directory. Basically if task B needs data from task A, task B will hit a blocking call in your code and sit there waiting till task A sends a message containing the data to be passed from task A to task B.
Sorry but I don't have any lwmsg example code handy or I'd post it. I think there are examples in the documentation and in the example projects that come with MQX.
MQX also has other things like semaphores and events that might work. It just depends on your situation.
Hope that helps,
Sean
1,151 次查看
sudhakarp
is possible to use global array in different task..?
