how to enter the task into a standby mode?
1,017 次查看
ggdggjjj
Hello/
I used KSDK 3 and MQX 1.2.
And i need question.
how to enter the task into a standby (Idle) mode?
874 次查看
danielchen
I think you can try the _task_block function, this function removes the active task from the task's ready queue and sets the BLOCKED bit in the STATE field of the task descriptor. The task does not run again until another task explicitly makes it ready with _task_ready()
875 次查看
danielchen
