how to create a blocked task using processor expert
1,312 次查看
hunglam
Hi, a quick question.. how can I create a blocked task using processor expert? if it cannot be done, how can I modify the task created by processor expert to a  blocked task? thanks
1,199 次查看
danielchen
Hi lam:
I think you can use the API  _task_block() to block the active task. The API removes the active task from the task's ready queue and sets the BLOCKED bit in the STATE field of the task descriptor. Please see the following task
void world_task
      uint32_t initial_data
   _task_id hello_task_id;
   hello_task_id = _task_create(0, HELLO_TASK, 0);
   if (hello_task_id == MQX_NULL_TASK_ID) {
      printf ("\n Could not create hello_task\n");
   } else {
      printf(" World 3000 \n");
   _task_block();
