get elaped time problem
1,840件の閲覧回数
BenG
I'm trying to experiment with _time_get_elapsed_ticks() and _time_get_elapsed().
In the following code the the values in the pointers aren't getting adjusted.
I.e. The value(s) are garbage and are unchanged.
I presume I'm doing something wrong or haven't set something correctly in the bsp/psp. But the Reference Manual doesn't state that I need to enable anything specific in the user_config.h file.
void nill_task (uint_32 initial_data){  MQX_TICK_STRUCT_PTR tick_time_ptr;  TIME_STRUCT_PTR     ms_time_ptr;    while (1)  {    _time_get_elapsed_ticks(tick_time_ptr);    _time_get_elapsed(ms_time_ptr);    __no_operation();    _time_delay(1023);  }}
 Any suggestions?
1,414件の閲覧回数
BenG
Worked it out.
The code should read.
void nill_task (uint_32 initial_data){  MQX_TICK_STRUCT tick_time;  TIME_STRUCT     ms_time;    while (1)  {    _time_get_elapsed_ticks(&tick_time);    _time_get_elapsed(&ms_time);    __no_operation();    _time_delay(1023);  }}
1,415件の閲覧回数
BenG
Worked it out.
