eth to serial does not work
davidzhu
Hi Support.
I have one problem about the demo mqx/rtcs/example/ethernet_to_serial
If I ping the IP address, I don't get a reply.
Is this normal?
danielchen
Hi @davidzhu :
Please read the readme file in the package.
1. BSP_DEFAULT_IO_CHANNEL should  be interrupted mode.
2.  use putty to connect TCP terminal.
If connection was successful following text is send to UART:
Serial <-> Ethernet bridge
And this text in TCP terminal:
Ethernet <-> Serial bridge
Please let me know if you need further information.
danielchen
Hi @davidzhu :
