error processing changed links in project descriptipn file
nacrotix
Hi everyone,
When i try to build MQX libraries, the error occur. Description of the error can be found in the attachment. Is there any solution ?
Thanks.
danielchen
Hi Jakub:
Do you have the administrative right of your PC?
nacrotix
Hi Daniel,
Thanks for your response. Problem was in the paths. I solved this by
reinstalation CW10.4. into to directory C:\Freescale... .Originally the path
was C:\ProgramFIles\Freescale .
Jakub
