build problem in TIMER example code
1,497 次查看
sudhakarp
i am using KDS 2.0 and KSDK 1.1.0 and FRDMk64 controller. i tried to build TIMER MQX example project but its showing following error.
undefined reference to `_timer_cancel'    main.c    /timer_frdmk64f/Sources    line 134    C/C++ Problem
undefined reference to `_timer_start_periodic_at_ticks'    main.c    /timer_frdmk64f/Sources    line 125    C/C++ Problem
in "mqx_sdk_config.h" file also i enabled following configuration
#ifndef MQX_USE_TIMER
#define MQX_USE_TIMER           1
#endif
     if anything i want to add..?
thanks and regards,
sudhakar p
in
1,305 次查看
sudhakarp
hi,
NOW I GOT IT..
     i forget to build "mqx_frdmk64".  lib.
regards,
sudhakar p
1,305 次查看
danielchen
Thank you for sharing
