Why would Keil crash when i open the build_libs project for twrk60n512?
jdwalther
I downloaded the 4.0.2 version of MQX to see if it would solve a problem that I am having.  I tried to load the build_libs.uvmpw to configure the libraries for what I need, and Keil crashes every time I open this project.  I have tried several times.  I can open other BSP's lib projects and they seem to work fine.  I have looked at the project file, and I don't see any issues that are obvious.  I even compared it to other project files and the only difference that I can see is the directory names.
Any thoughts or advice would be appreciated
Jay
jdwalther
This was solved by upgrading to Keil 5.0
