Why is MQX4.2 not compiling in Windows?
7,402 次查看
m4l490n
I'm trying to build the "hello" example for the FRDMK64F board but I'm getting this:
PS C:\Freescale\mqx4.2\mqx\examples\hello\build\make\hello_frdmk64f> .\build_gcc_arm.bat
mingw32-make: *** INTERNAL: readdir: No such file or directory
. Stop.
Press any key to continue . . .
. Stop.
. Stop.
. Stop.
. Stop.
. Stop.
But I'm not sure why. I have configured the TOOLCHAIN like this in the global.mak file:
ifeq ($(TOOL),gcc_arm)
GCC_VERSION ?=10.2.1
TOOLCHAIN_ROOTDIR = C:/nxp/MCUXpressoIDE_11.4.0_6237/ide/tools
endif
What am I missing?
4 回复数
7,201 次查看
Huey1
Hey! And what kind of Windows do you have? I am a work time developer, maybe I can help. We faced such a situation.
7,197 次查看
mmalagon
@Huey1 thanks for jumping in!
I'm on windows 10 enterprise Version 21H1
Just so you know, I'm getting this when running mingw32-make --version
GNU Make 3.82.90
Built for i686-pc-mingw32
Copyright (C) 1988-2012 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
And this from running which mingw32-make
/c/MinGW/bin/mingw32-make
So the program is definitely on my system. I just don't know what else does stupid windows wants.
7,396 次查看
danielchen
Hi @m4l490n :
From the release note, the development tools for MQX 4.2 is :
MCUXpresso IDE is not in the list.
MQX v5 can support MCUXpresso IDE.
7,386 次查看
m4l490n
@danielchen thanks for helping.
I'm not trying to compile MQX4.2 using MCUXpresso IDE, only trying to compile it using the arm-none-eabi-gcc version that gets installed by MCUXpresso IDE which by the way I can totally do in Linux by having this configuration in global.mak:
GCC_VERSION=10.2.1
TOOLCHAIN_ROOTDIR = /usr/local/mcuxpressoide-11.4.0_6237/ide/tools
endif
So I know this shall work, but my problem is that it doesn't work on windows and I don't know why.
