USB adapter driver
USB adapter driver
2,183 次查看
amleng
Hello all,
I use K60 tower kit and MQX 8.0 for my project. We have an idea to connect different comms such as Ethernet, WiFi, Bluetooth, .... to our product through host USB using adapters. Unfortunately, I couldn't find any "adapter driver" developed for MQX. Anybody has any information about this issue? Any suggestions? any idea?
Thank you
标记 (1)
1,838 次查看
c0170
Senior Contributor III
Hi amleng,
We have CDC NVIC example which supports old RNDIS version. We have also virtual COM (RS232) port example included in the MQX.
You can find the examples in usb/device/examples/cdc and usb/host/examples/cdc .
MartinK
1,838 次查看
c0170
Hi amleng,
can you specify what do you mean by "adapter driver"?
MartinK
1,838 次查看
amleng
For example if I want to use USB -Ethernet adapter. Is there any device driver+class driver available in MQX?
1,839 次查看
c0170
Hi amleng,
MartinK
