Triggering a task by an interrupt or timer
1,370 次查看
amleng
Hello MQX Community,
I would like to now how can I trigger a task by a hardware
interrupt or a timer? That means the task should wait for a trigger
in block state. Once the interrupt happened (e.g push a button) it
goes to non-block mode and process the data. The same
concept for timer...wait for a timer-overflow in block mode and
gets nonblock periodically.
Is there any sample code available that I can have look?
Cheers!
1,184 次查看
LuisCasado
Check this example:
C:\Freescale\Freescale_MQX_4_0\mqx\examples\event
Luis
