Timeline view doesn't work in example, and LOG_OVERWRITE crashes CW
811 次查看
OldPeculier
Hi all,
I'm testing timeline view with the example klog.c.  When I try to view, I get "No task switches found" and yet _klog_create returns MQX_OK, and _klog_control is set to the example default.  Moreover, MQX Log Summary view is showing 170 log entries under kernel logging.
Ironically it works in my application if _klog_create switch = 0.  The reason I am attempting the example is that if I set switch = LOG_OVERWRITE in my application, CW 3.8 crashes so hard I have to reboot the computer (W7).
Thanks for any help
Martin
726 次查看
c0170
Senior Contributor III
Hello Martin Hess,
there are missing few details, what's your target? what CW do you use? 3.8 is a version? what is the version of MQX? In order to reproduce what you have reported, we need the same configuration.
0xc0170
