Task Aware Debugger
Task Aware Debugger
ttocsmi
Hello.
Is there a setup document somewhere for using the Task Aware Debugger?  I have a K10 micro, codewarrior 10.2, and MQX 4.0.  I've followed the steps in the Getting Started with Freescale MX RTOS document, but it never connects to the micro.  Any help will be greatly appreciated.
Thank you.
soledad
Hello Scott,
Please check the attached video, this may helps.
Sol
LuisCasado
Check Freescale_MQX_4_2\doc\tools\cw\MQX_RuntimeTAD_Getting_Started.pdf
Luis
