Slider in HMI
Slider in HMI
1,819 次查看
LPs
Hi all,
  I'm trying to use HMI of MQX IO module to use analogue HW sliders.
I'm developing an application with Kinetis K10 micro.
I already use buttons without problems using HMI_LWGPIO_INIT_STRUCT, but I don't know how to configure analogue input to manage slider.
I saw that there is a TSS slider, but I have hw sliders connected to an analogue pin of micro.
标记 (3)
1,621 次查看
c0170
Senior Contributor III
Hello lucapetro,
I completely overlooked your post. Have you proceed with HW sliders? If no, can you provide more details?
HMI was intended to bridge two modules together - the lwgpio module and the touch sensing library. Do you want to use analog input (ADC) to sense a touch?
0xc0170
