Ping problem MQX RTCS Shell example
2,276 次查看
dmitriym
Hello.
I'm using MQX 4.0.1 and the MCU Coldfire MCF5282. I prepeared MQX files for MCU. Then i tried to use a shell mqx example, and connect MCU to PC.
Initialization of the module, configuration of ip settings works fine, i tried to ping MCU from PC, and it works fine too. I can see the correct ICMP packets in the Wireshark.  I also saw arp packets, and PC found my device and added it in its arp table.
But i have problems to ping PC from the shell. There is no ICMP packets in the wireshark at all.
Does anybody know the reason of that behavior?
标记 (3)
1,851 次查看
dmitriym
I've found the reason. It's very simple. I've disabled antivirus firewall and everything starts work fine.
1,852 次查看
dmitriym
