Result = 0xAE07, which is clearly not MQX_OK, and the error codes dont go past 0x00.
I have updated the code with another problem _task_abort doesnt work, always returns invalid _task_id..
/**HEADER********************************************************************
* Copyright (c) 2008-2009 Freescale Semiconductor;
* All Rights Reserved
* THIS SOFTWARE IS PROVIDED BY FREESCALE "AS IS" AND ANY EXPRESSED OR
* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
* IN NO EVENT SHALL FREESCALE OR ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT,
* INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
* SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
* STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
* IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
* THE POSSIBILITY OF SUCH DAMAGE.
* $FileName: adc_demo.c$
* $Version : 3.8.35.0$
* $Date : Sep-21-2012$
* Comments:
* This file contains the source for the ADC example program.
* Two channels are running, one is running in loop, the second one
* only once.
*END************************************************************************/
#include <mqx.h>
#include <bsp.h>
#if MQX_USE_LWEVENTS
#include <lwevent.h>
#endif
#if ! BSPCFG_ENABLE_IO_SUBSYSTEM
#error This application requires BSPCFG_ENABLE_IO_SUBSYSTEM defined non-zero in user_config.h. Please recompile BSP with this option.
#endif
#ifndef BSP_DEFAULT_IO_CHANNEL_DEFINED
#error This application requires BSP_DEFAULT_IO_CHANNEL to be not NULL. Please set corresponding BSPCFG_ENABLE_TTYx to non-zero in user_config.h and recompile BSP with this option.
#endif
#if defined(BSP_M51EMDEMO)
#define MY_ADC "adc1:" /* must be #1 as the inputs are wired to ADC 1 */
#define MY_TRIGGER ADC_PDB_TRIGGER
#if !BSPCFG_ENABLE_ADC1
#error This application requires BSPCFG_ENABLE_ADC1 defined non-zero in user_config.h. Please recompile BSP with this option.
#endif /* BSPCFG_ENABLE_ADCx */
#elif defined(BSP_TWRMCF51AG)
#define MY_ADC "adc:" /* must be #1 as the inputs are wired to ADC 1 */
#error This application requires BSPCFG_ENABLE_ADC defined non-zero in user_config.h. Please recompile BSP with this option.
#elif defined(BSP_TWR_K70F120M) || (BSP_TWR_K60N512) || defined(BSP_TWR_K40X256) || defined(BSP_TWR_K40D100M) ||\
defined(BSP_TWR_K53N512) || defined(BSP_TWR_K60F120M) || defined(BSP_TWR_K60D100M) || defined(BSP_TWR_K20D72M)
#elif defined(BSP_KWIKSTIK_K40X256) || defined(BSP_TWR_K20D50M) || defined(BSP_TWR_K21D50M)
#define MY_ADC "adc0:"
#if !BSPCFG_ENABLE_ADC0
#error This application requires BSPCFG_ENABLE_ADC0 defined non-zero in user_config.h. Please recompile BSP with this option.
#elif defined(BSP_TWRMCF51JF) || defined(BSP_TWRMCF51QM)
#elif defined(BSP_TWRMCF51MM) || defined(BSP_TWRMCF51JE)
#endif /* BSPCFG_ENABLE_ADC */
#else /* defined BSP_xxx */
#define MY_TRIGGER ADC_TRIGGER_1
#endif /* defined BSP_xxx */
/* Task IDs */
#define MAIN_TASK 5
#define TEST_TASK 6
/* Function prototypes */
extern void main_task(uint_32);
extern void test_task(uint_32);
const TASK_TEMPLATE_STRUCT MQX_template_list[] =
/* Task Index, Function, Stack, Priority, Name, Attributes, Param, Time Slice */
{MAIN_TASK, main_task, 2000, 8, "Main", MQX_AUTO_START_TASK, 0, 0 },
{TEST_TASK, test_task, 1000, 10, "test_task", 0, 0, 0 }, //TEST
{0}
/* ADC device init struct */
const ADC_INIT_STRUCT adc_init = {
ADC_RESOLUTION_DEFAULT, /* resolution */
static LWEVENT_STRUCT evn1;
static LWEVENT_STRUCT evn2;
static LWEVENT_STRUCT evn3;
#endif
/* Logical channel #1 init struct */
const ADC_INIT_CHANNEL_STRUCT adc_channel_param1 =
ADC_SOURCE_AN5,
ADC_CHANNEL_MEASURE_LOOP | ADC_CHANNEL_START_TRIGGERED, /* runs continuously after IOCTL trigger */
10, /* number of samples in one run sequence */
0, /* time offset from trigger point in us */
300000, /* period in us (= 0.3 sec) */
0x10000, /* scale range of result (not used now) */
10, /* circular buffer size (sample count) */
1, /* logical trigger ID that starts this ADC channel */
&evn1,
0x01 /* mask of event to be set */
/* Logical channel #2 init struct */
const ADC_INIT_CHANNEL_STRUCT adc_channel_param2 =
ADC_SOURCE_AN7,
2, /* logical trigger ID that starts this ADC channel */
&evn2,
const ADC_INIT_CHANNEL_STRUCT adc_channel_param3 =
ADC_SOURCE_AN4,
4, /* logical trigger ID that starts this ADC channel */
&evn3,
/*TASK*-----------------------------------------------------
** Task Name : main_task
** Comments :
*END*-----------------------------------------------------*/
_task_id TEST_Task_ID = 0;
void Exit_Handler(void)
printf("Aborting Task\n");
void test_task(uint_32 x)
_task_set_exit_handler(TEST_Task_ID, _CODE_PTR_ Exit_Handler);
for(;;)
printf("Hello from test_Task\n");
_time_delay(2000);
void main_task
uint_32 initial_data
ADC_RESULT_STRUCT data;
uint_32 error = 0;
_mqx_int i;
MQX_FILE_PTR f, f_ch1;
MQX_FILE_PTR f_ch2;
MQX_FILE_PTR f_ch3;
printf("\n\n-------------- Begin Abort Task example -------\n\n");
printf("Creating test task\n");
TEST_Task_ID = _task_create(0, _task_get_template_index("test_task"), 0);
printf("Test Task Created = %X\n", TEST_Task_ID);
_time_delay(10000);
printf("Abort Task ID = %X\n", TEST_Task_ID);
error = _task_abort(TEST_Task_ID);
printf("Task abort returned %X", error);
printf("\n\n-------------- Begin ADC example --------------\n\n");
if (_lwevent_create(&evn1, 0) != MQX_OK) {
printf("\nMake event failed!\n");
_task_block();
if (_lwevent_create(&evn2, 0) != MQX_OK) {
_task_block();
if (_lwevent_create(&evn3, 0) != MQX_OK) {
_task_block();
#endif
printf("Opening ADC device ...");
f = fopen(MY_ADC, (const char*)&adc_init);
if(f != NULL)
printf("done\n");
else
printf("failed\n");
_task_block();
printf("Opening channel #1 ...");
f_ch1 = fopen(MY_ADC "first", (const char*)&adc_channel_param1);
if(f_ch1 != NULL)
printf("done, prepared to start by trigger\n");
else
printf("failed\n");
_task_block();
printf("Opening channel #2 ...");
f_ch2 = fopen(MY_ADC "second", (const char*)&adc_channel_param2); /* adc:2 is running now */
if(f_ch2 != NULL)
printf("done, one sequence started automatically\n");
else
printf("failed\n");
_task_block();
printf("Opening channel #3 ...");
f_ch3 = fopen(MY_ADC "third", (const char*)&adc_channel_param3); /* adc:2 is running now */
if(f_ch3 != NULL)
else
printf("failed\n");
_task_block();
_time_delay(1000);
printf("Triggering channel #1...");
ioctl(f, ADC_IOCTL_FIRE_TRIGGER, (pointer) ADC_TRIGGER_1);
printf("triggered!\n");
#warning ADDED CODE Here for channel 3
printf("Triggering channel #2...");
ioctl(f, ADC_IOCTL_FIRE_TRIGGER, (pointer) ADC_TRIGGER_2);
printf("Triggering channel #3...");
ioctl(f, ADC_IOCTL_FIRE_TRIGGER, (pointer) ADC_TRIGGER_3);
for(i = 0; ; i++)
/* channel 1 sample ready? */
if (read(f_ch1, &data, sizeof(data) ))
printf("ADC ch 1: %4d\n", data.result);
else
printf(" ");
/* channel 2 sample ready? */
if (read(f_ch2, &data, sizeof(data) ))
printf("ADC ch 2: %d\n", data.result);
else
printf("\n");
/* channel 3 sample ready? */
if (read(f_ch3, &data, sizeof(data) ))
printf("ADC ch 3: %d\n", data.result);
else
printf("\n");
if (i == 37) {
printf("Pausing channel #1...");
if (IO_OK == ioctl (f_ch1, ADC_IOCTL_PAUSE_CHANNEL, NULL))
printf("stopped!\n");
else
printf("failed!\n");
if (i == 53) {
printf("Resuming channel #1...");
if (IO_OK == ioctl (f_ch1, ADC_IOCTL_RESUME_CHANNEL, NULL))
printf("resumed!\n");
else
_time_delay(100);
printf("Waiting for event...");
if (_lwevent_wait_ticks(&evn1, 0x01, TRUE, 0) != MQX_OK) {
else
printf("succeed!\n");
#endif
/* close all ADC channels */
printf("Closing channels...");
fclose(f_ch1);
fclose(f_ch2);
fclose(f);
printf("done!\n");
_task_block();
/* EOF */
