MQX3.7 TCP socket timeout problem
5,784 次查看
javier1
Hi to all,
I´m using MQX 3.7 in a custom board with Kinetis K60DN512 MCU, and I´m using this board with RTCS TCP in server mode (It´s connected with a PC asking data).
If PC is communicating with board works fine, but if I stop communicating 15 minutes, I can no longer communicate with the board. I have based on the example socket.zip (A socket proggraming demo for MQX / RTCS).
That is, when the 15-minute timeout operates, I don't know that a new communication is arriving. In document MQXRTCSUG.pdf, in 2.15.1 section (Changing inactivity timeouts) This timeout is 15 min. default.
How can I solve this problem?
Regards.
5,760 次查看
danielchen
Hi Javier:
Sorry MQX 3.7 is a very old version.   Now the latest version is MQX v5. Please refer to below link for more details.
https://www.nxp.com/design/software/embedded-software/mqx-software-solutions/mqx-v5-software-solutio...
The latest free MQX version is V4.2.0  + patch 4.2.0.2.
Please refer to my attached change log for MQX RTOS,  Lots of bug fixes in MQX 4.2.0, and it is more stable.
5,760 次查看
danielchen
Hi Javier:
