MQX3.2 USB CDC Window7 64 bit issue
2,286件の閲覧回数
wenxue
Customer:Qinghuangdao Haiwan
Customer use coldfire mcf52274 and MQX 3.2, they use USB CDC class, USB works OK for Window7 32bit but failed on Window7 64 bit. Do you know how to solve this issue? Thanks.
Best Regards
Wenxue
3 返答(返信)
1,922件の閲覧回数
soledad
Unfortunately MQX 3.2 is not supported. You can try using the MQX3.8 INF file (attached to this thread) this drver supports Windows 64bit.
Sol
1,922件の閲覧回数
wenxue
Hi Sol,
thanks for you help. unfortunately when customer use this inf file, USB CDC can't be enumerated successfully.
Any other suggestions?
Wenxue
1,922件の閲覧回数
soledad
Sorry but MQX 3.2 is not longer supported, please suggest to your customer migrate to MQX 3.8.
Sol
