MQX3.2 USB CDC Window7 64 bit issue
wenxue
Customer:Qinghuangdao Haiwan
Customer use coldfire mcf52274 and MQX 3.2, they use USB CDC class, USB works OK for Window7 32bit but failed on Window7 64 bit. Do you know how to solve this issue? Thanks.
Best Regards
Wenxue
soledad
Unfortunately MQX 3.2 is not supported. You can try using the MQX3.8 INF file (attached to this thread) this drver supports Windows 64bit.
Sol
wenxue
Hi Sol,
thanks for you help. unfortunately when customer use this inf file, USB CDC can't be enumerated successfully.
Any other suggestions?
Wenxue
soledad
Sorry but MQX 3.2 is not longer supported, please suggest to your customer migrate to MQX 3.8.
Sol
