I am trying to integrate into MQX a quite complex 3rd party piece of code, this code requires me to use MFS for the file system but also requires me to include the standard header <stdio.h> .
Adding this header as shown below will cause a compile error even for the trivial example below
#include <stdio.h> // Grrr this causes header clash#include "mqx.h"#include "fio.h"#include "mfs.h"void doSomething(void){}
Error : identifier 'FILE' redeclared
was declared as: 'struct _FILE'
now declared as: 'struct file_struct'
fio.h line 153 } FILE, _PTR_ FILE_PTR;
To reduce the errors down to just this "FILE" variable clash I had to declare the macro "MQX_SUPPRESS_STDIO_MACROS"
I have no idea how to fix this last error , can anyone suggest a tidy fix please ? I tried kludging out the clashing item in "cstdio" but that didnt seem sensible and it triggered more compile faults anyway.
Thanks for any suggestions
Geoff
