I need a 1ms timer interrupt, what is the best way in MQX to make this happen?
Solved! Go to Solution.
I'm having no problems with GPT timer and direct ISR for it, with no MQX intervention. You can do the same direct interrupt with DMA timers.
Ther are several topics about that
Awesome, I will do that Lord Mark.
