MQX on imxrt1020 with Keil
oyvigre
I am using Keil to develop and compile my application, it has previously ran on K60 with MQX 4.1, and I am planning to port this to MQX 5.2 on IMXRT1020.
I have bought a MQX release, where the libraries are built with MCUXpresso and gcc compiler. Is it bad practice to have MQX compiled with a different compiler than my main application (Keil-compiled)?
How do you suggest that I proceed, should I aim to build MQX with Keil?
oyvigre
I will contact that mail. Enabling "GNU extensions" in Keil helped a lot already, though.
danielchen
Hi @oyvigre :
I would suggest you contact mqxsales@nxp.com.  It should can support MCUXpresso, IAR, and Keil.
