MQX: is mutex reentrant?
1,911 次查看
huishao2
Hi-
To better understand how mutex works in MQX, I have a question about if mutex is re-entrant. For example, if a task has locked the mutex and tries to lock it again without unlocking it, what would happen?
thanks!
Hui
标记 (1)
1,651 次查看
soledad
Please check the  below thread.
MQX Mutex question
I hope this helps!!!
Sol
1,652 次查看
soledad
MQX Mutex question
Sol
