MQX + PE for SDK cannot be build with default language standard in KDS toolchain
1,282 次查看
matejhybler
MQX + PE for SDK cannot be build with default language standard in KDS toolchain. To be able to build libs please use GNU ISO C99 (-std=gnu99) language standard.
To change this setting select project and then go to: Project->Properties, then select Settings from C/C++ Build. In the tab Tool Settings choose Optimalization from Cross ARM C Compiler. Now you can change language standard from menu.
Screenshot with required setting is attached. This problem will be fixed in SDK 1.1.
Matej Hybler
MQX team
标记 (5)
0 回复数
