MQX FILE I/O
MQX FILE I/O
3,975 次查看
parkjaeyeon
Hi everyone.
I use K60 and MQX 4.0.
There is no external NAND flash on my board.
I want to save configuration information using the internal NAND flash.
How to store configuration information using the internal flash?
Please Help Me!!
3,724 次查看
KJFPE
Have a look at flashx
                flash_hdl = fopen(“flashx:”, NULL);    // Open the flash device
example project at
C:\Program Files\Freescale\Freescale MQX 3.8\mqx\examples\flashx
C:\Program Files\Freescale\Freescale MQX 3.8\mqx\examples\flexnvm
4 回复数
3,725 次查看
KJFPE
example project at
3,724 次查看
JuroV
internal flashes are usually of type NOR.
3,724 次查看
KJFPE
Does it really matter, he wants to store his configuration data and flashx will solve the problem it may not be NAND flash but it will be easier to write to  (NOR allows random-access, NAND allows only page access)  I was just trying to give some helpful advice.
3,724 次查看
JuroV
I just corrected you, that's all. :smileygrin:
