I am using KDS for a project with a Kinetis MK10 on one version and a Kinetis MK12 on the other.
I am using KDS 2.0.0 with MQXLite 1.1.1 and a Segger J-link debugger. I have the MQX Task Aware Debugger for GDB installed and when I am debugging the application I can use the MQX views to see the task list, Kernal Data, Lightweight event status, stack usage etc.
However, this works on the first time I start a debug session. If I ever stop the debugger and terminate the session then start a new session, the views no longer work.
Stack usage displays: Stack usage information not found!
Task List: Task list not retrieved successfully!
and so on.
I have tried uninstalling the plug in and re-installing it though the update site with the same results.
Any insights would be great.
