MQX 4.2 Missing CodeWarriorNPW folder
1,437件の閲覧回数
danir_
MQX 4.2 clones correctly with the BSPCloningWizard. But this update losts the reg32 & 64 files & xmls.
It is a bug ?
1,277件の閲覧回数
RadekS
Hi Dani,
Thank you for your bug report.
You are right, this feature missing in current version of BSP Cloning Wizard tool.
We changed type of generators (now it is ruby) and we miss this point.
I will report it into our internal bug database.
Note: *.xml and *.reg files are in readable format therefore you can edit them by any text editor.
I generated MY_BOARD411 BSP from frdmk64f BSP. You could take xml file, modify "MY_BOARD411" BSP name into your name and modify MCU type. In reg file you should replace "MY_BOARD411" by your BSP name and edit path to MQX4.2 with MQX version. After that, it should work even with MQX4.2
I hope it helps you.
RadekS
1,277件の閲覧回数
danir_
Thanks, I used 4.1.1 files and I updated for 4.2.
