MFS, how get the handle of a file?
1,480 次查看
emanueletrapani
i work on a k64f, MQX 4.2.
There is a way to recover the handle of a opened file if i miss the fopen() return handle?
I have the pathname and the filename.
thank you
Emanuele Trapani
标记 (1)
1,315 次查看
danielchen
Hi Emanuele:
File handle is a memory allocated for the given FILE_PTR from system memory pool.  Theoretically, it is possible to get it by walking through kernel data. Unfortunately MFS does not provide this API to do that.   You can save the fopen returned file handle into a global variable. I don't think it will be missed .:)
