MFS at internal flash
已解决
跳至解决方案
2,573 次查看
Tgomes
Is there a simple way to use the internal flash to store and manipulate files by using MFS? If so, it is possible to know or configure how much space I have available?
Tgomes.
标签 (1)
标记 (1)
1 解答
1,954 次查看
Tgomes
Resolved (in another way)
I decided to work with the file system on a sdcard, available on my board. Now I have enough space to save my files and create folders.
Thanks for help!
在原帖中查看解决方案
3 回复数
1,954 次查看
timias
Did you look at the RAM Disk Example?
1,954 次查看
Tgomes
Timias, Yes, but use the MFS in RAM would not be appropriate for my project. Thank you for answering! Att.
1,955 次查看
Tgomes
Thanks for help!
