MQX™ Software Solutions are available in three variants to meet your embedded design needs: traditional MQX RTOS; MQX Lite; and MQX RTOS for Kinetis SDK.
The TWR-K60D100M_Quick_Start_Demo was developed using traditional MQX RTOS version 4.0 with both CodeWarrior MCU 10.4 and IAR 6.50.6. So you need to install traditional MQX in order build and debug this example.
If you want to use KDS + traditional MQX, you need to install MQX 4.2. After install MQX you can find examples at the paths:
C:\Freescale\Freescale_MQX_4_2\mqx\examples
C:\Freescale\Freescale_MQX_4_2\demo
In order to create a new MQX project, please check the below link: https://community.freescale.com/docs/DOC-106217
If you want to use KDS + MQX for KSDK you can find some examples at the path:
C:\Freescale\KSDK_1.2.0\rtos\mqx\mqx\examples
In order to create a new MQX for KSDK project, please check the below link:
I hope this helps,
Sol
