Interupt Pin Control
1,494 次查看
projektecarus
I have a TWR_K60F120M device and want to install a Interupt service routine, which gets activated by a input pins rising edge. I already raed the example and the Towers manual. As far as I understand there is a pin control register. How do I change this control register and how can i get my wished ISR working??
1,416 次查看
Martin_
You can use MQX lwgpio driver. There is the source code example for lwgpio usage in MQX installation folder, in /mqx/examples/gpio/gpio.c, already with an interrupt from MCU board push button.
