IPCFG_default_ip_gateway = 0
rdazcal
All over the RTCS code I see:
What does it means gateway = 0? Shouldn't it be some valid gateway ip address?
PetrM
Senior Contributor I
It depends on your network. If there are gateways, you have to assign its IP address to this variable. Be sure you have also enabled RTCSCFG_ENABLE_GATEWAYS in your user_config.h.
PetrM
PetrM
PetrM
rdazcal
Thanks PetrM
